I have a kenmore elite model 74994 and have replaced the start button but, the dryer still won't stay on unless holding the button in. I have held the button in and everything runs and get warm. I also, opened the door with the button held in and the dryer shuts off when I open the door. I would appreciate some help with this problem and thanks
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
SOURCE: My Kenmore Elite Total Care System with Evenheat
It sound`s to me based on your description, the start relay/switch is faulty. (the other unlikely possibility is the start switch in the motor).
If you call a local part`s supplier or check out searspartsdirect.com, apwagner, partsdepot, repairclinic etc. with your model & serial number, they should have that part for you.
Hope that help`s you. Please take a second and rate the information provided to you here at fixya.
Thanks for visiting fixya and good luck.
macmarkus :)
I pulled the heater relay and switched it with the motor relay and the dryer runs now, it was the motor relay, i am just happy that i was able to check it using the heater relay
