Question about Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
Computer not recognizing it
I installed a Hd into the nextstar and double checked it...it seems to running fine but my laptop will not recognize the new drive. what do I need to do? I run a PC with windows Xp on it. I have a feeling I am supposed to do something else...what's up? can you help?
    Novelist:
    Scholar:
  • 158 Answers
If as you say its working fine is pc accessing drive via usb and have you set the jumper to master as most external enclosures work on the device being master if you can see the hdd on pc then the laptop needs to have windows re-installed but if the pc is not showing hdd then goto control pannel and Administrative Tools and Computer Management and then Disk Management if showing here then select unallacated drive and properties and set active. then turn of drive then turn back on and see if comes up in my computer. only do laptop if pc has hdd viewing in my computer. hope all goes well
Posted on Aug 14, 2007
The HD suddenly stops getting recognized by the laptop, in the middle of any action.
Sounds like a conflict. Disconnect any other USB attached devices while running HD. Worked for me with same problem.
Aug 26, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
My 500GB Elements external hard drive is not being recognized by my computer
check usb cable first might try another cable to be certain it's not communications
and afterwards, you might consider running this utility to optimize your ext drive
Jun 16, 2012 | Computers & Internet
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
Computer (Vista) stopped recognizing camera when
you will need to update the drives. They are free to download. Many websites including Fuji, have them available. Just click, download, then double-click the file to install onto pc. Then restart pc, turn on camera, then connect it and you'll be fine.
Jan 27, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
I Can't get Print Shop 23 to install on my Vista laptop
Hi There,
Click the Start in the lower left hand corner of your screen
Click on My Computer
Double Click The Drive that has the disc
Click Run or Install
Let me know if this helps.
Mar 29, 2009 | Broderbund The Print Shop 22 Deluxe Full...
1) Start up sometimes freezes, 2) Is not recognizing outlet power
Hi.
i recommend You in this Case to format and install a new OS
Windowns XP.
good luck
Dec 12, 2008 | Acer Aspire 3002LCi Notebook
Dell inspiron 1526 laptop
double-click MY Computer
Double-click the CD Rom Drive
You should see a file called setup, double-click it, the install should run
Jun 21, 2008 | Dell Inspiron 1501 Notebook
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
Firelite 160gb HD not recognized
Make sure that there is no "HD protection", in which the hard drive can only be connected to one computer. Also, try going to google and searching for some drivers for your computer to download and install. Then try plugging your hard drive in again.
Dec 28, 2007 | FireLite (USBFLB80) Hard Drive
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case Logo
219 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
Willem.
Willem.
Piyal Perera
Piyal Perera
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
