Question about Dishwashers
Drawer dish washer - fault U1 comes up as washing cycle begins
What is the fault and how to fix it?
    Sergeant:
    Novelist:
  • 327 Answers
This is usually some type of water fill deficiency problem. You'll need to remove the lower drawer to access the fill valve at the back of the drawer compartment on the left hand side
Posted on Dec 23, 2008
Indesit IDL 850 dishwasher: dishes in the top drawer ONLY are dirty: residues is left on and inside what is in the top drawer, so that they come out dirtier than when they went in. This is new: I have not...
If he Dishes Are Not Clean:
- Have you put the right amount of detergent into the dispenser?
- Is the wash cycle suitable for the dishes you have placed inside the
appliance?
- Are the filter and microfilter clean?
- Can the sprayer arms turn freely?
This is how the manual helps.
Jun 29, 2017 | Indesit Dishwashers
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have fisher&paykel.dishwasher.nautilus, half way through the washing,it beeps non stop and shows me U1 . AND IT DOESNT WORK SO I HAVE TO START ALL OVER AGAIN
U1 fault if caused by several things: water supply not turned on (I doubt that), unit is syphoning causing not water in tub to be detected during cycle (this is possible if the drain system in incorrectly installed), spray arm in the drawer is not in place or get moved somehow, excessive foaming (wrong soap or too much), inlet valve failed, controller failed, or rotor not fitted correctly.
I would inspect this issues and locate the reason the unit will not complete the cycle, you may end up replacing the controller in that drawer to fix the problem (as a last resort).
Good Luck
Oct 11, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water backs up in my lower Fisher & Paykel dish drawer
Make sure the line that water exits from is up high enough that it cannot back up.The instructions say to keep the line as high as possible.
May 21, 2009 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dish drawer
U1= Machine has failed to prime with water within
approx. 3 minutes
 The water supply is not turned on
 The machine is syphoning
 The spray arm is not in place
 Excessive foaming
 The Inlet Valve has failed
 The electronic controller has failed
 Rotor not fitted correctly
Jun 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
Jun 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water leaking and dial spinning
unconnected faults. does water come out of drawer when filling? if so fault is a blockage in hose down to tub from drawer or drawer may need cleaning if fault happenns on rinse. fault on knob is broken inner knob and poss cam as well
Mar 14, 2007 | Zanussi FLA1201W Front Load Washer
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
