Question about Akai PT5492S 54" Rear Projection Television
AKAI 54" rear projection TV
I have an AKAI rear projection TV the AUTO FOCUS comes on with the message "Check Factory Data" and won't focus. Any ideas?
    President:
  • 1,284 Answers
The convergence sensors either need to be re-initilized or one of them is bad. The service menus needs to be acsessed to re-initilize the sensors.
Posted on Apr 09, 2007
I have an akai rear projection big screen tv that has blue shadows on everything. When the auto focus turns on, about half way through the process, everything clears up. When the auto focus completes, the...
Replace the Blue convergence IC, But you should consider replacing both of them, because if one has failed then the other is likely to sooner or later. They are large Black IC's mounted on a Metel Heatsink. I believe on this model the board is in the middle of the unit. Before you replace check the solder connection on the Ic's first you might just have a few cold solder joints, if not then replace both IC's
Nov 09, 2009 | Akai PTH5498 54" Rear Projection...
The picture went fuzzy (color alignment).
craighirman,
try going to the antenna input from the menu screen, then trying to do the auto focus, or manual focus. My Samsung won't let me do the auto focus unless I'm looking at the antenna for some strang reason.
Oct 18, 2008 | Samsung PCL545R 54" Rear Projection...
Auto Focus Stoped Working
If the convergence is very far off the convergence ICs are bad and need to be replaced first. If the convergence is close and it wont correct it might just be an insect or some dust on the sensors at the 12, 3, 6 and 9 o'clock posistions behind the screen.
Jun 04, 2008 | Akai PTH5498 54" Rear Projection...
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
Nov 11, 2017 | Akai PTH5498 54" Rear Projection...
Check Factory Data after fixing convergence and resistors
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
May 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
"check factor data" using self focus
Hi.
Not at all familiar with your tv but this sort of message comes up if you have altered eeprom settings while in engineers mode.
To put it right you will need the work shop manual to know how to reset the settings.
Maybe A tech on these forums can help you out.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Akai PT4799HD Rear Projection Television
Auto Focus not working.
I think your having convergance problems.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Akai PT5598HD 55" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Actually...it's a Akai PT5299HD
I HAVE A AKAI PT5299HD TV AND WHEN I PUT ON THE AUTO FOCUS THE TV KEEPS TRYING TO FOCUS ENDLESSLY BUT DOES'NT FOCUS. IS THERE A WAY TO MANUALLY FOCUS THIS TV-MY WRITING ON THE SCREEN IS BLURRY?
Jul 31, 2006 | Akai PT5598HD 55" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
133 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
