Computers & Internet Logo
Anonymous Posted on Aug 31, 2012
Can bully game run on windows xp service pack 2?
I love bully game but i have windows xp service pack 2 and i want to know whether i can play that game or not
kermit green
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Oct 28, 2013
kermit green
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
12611
Points
78
What a horrible game. Have you tried lemmings or theme hospital.
I am sure it will work on Xp.
4 Related Answers
Anonymous
  • 151 Answers
  • Posted on Sep 28, 2007
SOURCE: how to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
A
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Drivers
hey bodies I have successfully install and convert my toshiba satalite A200-13O from vista to win XP professional but some drivers particularly modem and sound could not work.what shall I do please? even I have down load and try to install that but still unable to work
thanks
Anonymous
  • 155 Answers
  • Posted on Jan 05, 2009
SOURCE: I want to delete games from Windows XP
You can't delete them but you can disable them. Go to control panel. Click add/remove programs. Click Add/remove windows components from the left side. Games is under accessories.
Anonymous
  • Posted on Jul 22, 2009
SOURCE: Need Windows XP Service Pack 3 kstvtune.ax
Got a web camera. Didn't work. Said, I needed "kstvtune.ax" and a couple other small files. Couldn't find them anywhere, or downloadable versions. Listened to a lot of advice on blogs. Nothing worked. Finally, I went to the Microsoft Website and downloaded Service pack 3 AGAIN for Windows XP, from scratch. Takes time to download, even at high speed, but it's worth it. First try my camera worked beautifully. THIS IS THE FREE FIX THAT REALLY WORKS! It will get you all the files you need, which may have been knocked off by virus scans, or whatever caused the lack of files for your web camera. Go do it!
Im trying to run nhra drag racing2 on windows vista but I get a black screen when trying to play game although i can hear game music in background. the task manager screen says that the game is not...
Since the game was released in 2002 it may have a few problems running on today's systems. I would first try running it in compatibility mode. Right click on the icon you use to launch the game and go to properties. From there click on the compatibility tab. Select the check box that says "Run this program in compatibility mode for" and then from the drop-down box select Windows XP (Service Pack 3). Then click Apply and OK. Then try launching the game again and see if it runs any better. If not, try it again but in compatibility mode for XP (Service Pack 2). Good luck!
tip
What Does It Mean When Support for My Operating System Ends?
Microsoft Support for Windows Vista (with no service packs installed) ended on April 13, 2010, while support for Windows XP (without Service Pack 3 installed) ended on July 13, 2010. Windows 2000 support ended on July 13, 2010 as well.
There is no Service Pack 3 for the 64-bit version of Windows XP. If you're running the 64-bit version of Windows XP with SP2, you have the latest service pack and will continue to be eligible for support and receive updates until April 8, 2014.
If you are still running a version of Windows where support has ended, it means that version of Windows will no longer receive any updates from the Windows Update or Microsoft Update site. These updates are generally provided for security reasons to help protect the PC from harmful viruses, spyware, malware, and other malicious software. Windows Update also provides new drivers for your hardware that can improve the reliability of Windows.
Hackers love to take a security vulnerability in Windows and exploit it to their advantage. So, if a vulnerability is found in Windows XP or Windows Vista and you are not running the latest service pack, you will not be protected and will be at risk.
How Can I Tell What Service Pack is Installed?
Follow these steps to discover what Service Pack is installed:
1) Click on the Start Button
2) Right-click on either My Computer or Computer (depending on your Windows version)
3) Click on Properties
On this window, it should tell you which version of Windows along with which service pack is installed). It should also tell you whether you are running a 32 bit or 64 bit version of Windows.
Where can I download the latest Service Pack for Windows?
For Windows XP, click on the following link to download Service Pack 3
For Windows XP Service Pack 3 info, click below :-
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
For Windows XP Service Pack 3 download, click below :-
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4
For Windows Vista, click on the following link to download Service Pack 2
Windows Vista Service Pack 2 info, click below :-
http://windows.microsoft.com/en-us/windows-vista/Learn-how-to-install-Windows-Vista-Service-Pack-2-SP2
Windows Vista Service Pack 2 download, click below :-
http://support.microsoft.com/kb/935791
on Oct 04, 2010 • Computers & Internet
4helpful
Can windows 7 run GTA IV.
Running GTA 4 on windows 7 should not be a problem. You just have to run the installer using compatibility mode. Right click on the "setup.exe" then choose Properties. Go to Compatibility tab and tick "run this program in compatibility mode for", choose windows xp sp 3. That should allow you to install GTA 4 on windows 7. Bear in mind that you have to install GfW Live and the C++ 2005 files seperately which can be found in the disk as well. More importantly, make sure that your computer meets the system requirements for the game.
Here it is: System Requirements
Minimum System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz Memory: 1.5GB, 16GB Free Hard Drive Space Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista) 18 GB Free Hard Drive Space Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
After installing the game and you're not able to run it, Try running the main executable file of the game in compatibility mode as well.
Hope this helps.
2answers
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
I am in pakistan my xbox 360 is from america.when i put bully game in my xbox a message pops us that that sorry this game cannot be played because the region code didnt match.i love bully game i wanna play...
o mary bhai.
region free game lya kro.if your xbox is NTSE then it wont play PAL games,you only to do
to bay a new game in your region ok or region free games
AGER SMJ NAHI AYE TO MJY MAIL KRO.DONT WORRY
[email protected]
1helpful
2answers
What is the different between xp serrvice pack 1 and 2
A service pack is a collection of all updates released to that point, and often includes new features, as well.
The major enhancements in Windows XP Service Pack 2 include Security Center, Automatic Updates, Windows Firewall, and Internet Explorer.
Security Center is an entirely new feature provided by Windows XP Service Pack 2. The Security Center service runs as a background process in Windows XP and routinely checks the status of the following components:
1. Windows Firewall: Security Center detects whether Windows Firewall is enabled or disabled. Security Center can also detect the presence of some third-party software firewall products.
2. Automatic Updates: Security Center detects the current Automatic Updates setting in Windows XP. If Automatic Updates is turned off or not set to the recommended settings, the Security Center provides appropriate recommendations.
3. Virus Protection: Security Center detects the presence of antivirus software from many third-party organizations. If the information is available, the Security Center service also determines whether the software is up-to-date and whether real-time scanning is turned on.
When Security Center detects an important security condition (such as improper settings), it displays a pop-up notice in the notification area.
Windows XP Service Pack 2 provides several enhancements to the Automatic Updates feature, including the following:
■ The latest version of Automatic Updates offers expanded support for Microsoft products, including Microsoft Office.
■ Previous versions of Automatic Updates could download only critical updates. Now Automatic Updates can download updates in the following categories: security updates, critical updates, update roll-ups, and service packs.
■ Automatic Updates now prioritizes the download of available updates based on the importance and size of the updates. For example, if a large service pack is being downloaded, and a smaller security update is released to address an exploit, that security update will be downloaded more quickly than the service pack.
■ Automatic Updates is now more automated. The need for users to accept End-User License Agreements (EULAs) has been eliminated. Also, the user now has a choice of whether to restart the computer following the installation of updates that might require a restart. Updates that do require a restart can now be consolidated into a single installation so that only one restart is required.
Previous versions of Windows XP include a software-based firewall named Internet Connection Firewall (ICF). After installing Windows XP Service Pack 2, this firewall is replaced by Windows Firewall.
Windows Firewall boasts a number of enhancements, including the following:
1. Windows Firewall is now enabled by default on all network
connections.
2. Windows Firewall provides an interface for configuring global settings that apply to all the connections of the computer.
3. In Windows XP Service Pack 2, Windows Firewall supports a new feature that allows you to keep Windows Firewall enabled and also not allow any exceptions; only solicited traffic is allowed. This new feature is intended to create an even more secure environment when connecting to the Internet in a public location or other unsecured location.
4. In Windows XP Service Pack 2, a startup Windows Firewall policy performs stateful packet filtering during startup, so that the computer can perform basic network tasks (such as contacting
DHCP and DNS servers) and still be protected.
5. In previous versions, you could not apply firewall rules based on Internet Protocol (IP) addresses. In Windows XP Service Pack 2, you can configure Windows Firewall so that firewall rules apply to IP addresses (or IP address ranges), meaning that only traffic from computers with valid IP addresses is allowed through the firewall.
6. In previous versions, you configure permitted traffic by specifying the TCP and UDP ports used by a service or application. In Windows XP Service Pack 2, you can also configure permitted traffic by specifying the file name of the application. When the application runs, Windows firewall monitors the ports on which the application listens and automatically adds them to the list of allowed incoming traffic.
Internet Explorer:
Windows XP Service Pack 2 introduces a number of new security features to Internet Explorer 6. As with the rest of the enhancements introduced with Windows XP Service Pack 2, most of the updates to Internet Explorer are intended to provide better security.
2answers
Halo 2 for pc
The reason is, it only happens when you try to install Halo 2 on Windows XP.
The Game gets installed perfectly on Windows Vista
Because, I have installed and played the game on Windows Vista. But, when I de-graded my OS to Windows XP and tried to install the game. It gave me the same error message.
So, if your OS is Win XP then try install on Win Vista if you have it or on your friends PC.
But if you are already on Win Vista then please do let me know.
Also could please let me know whether your trying to Auto install the game or you are manually trying to install the game by clicking Step.exe?
I would be glad to find some help for you in this regard.
Games not playing in xp sp 2 pro
Whats the game? How much memory do you have? what size processor and video card do you have? These will determine whether a game will play.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
