Question about Alps MD 1300 Thermal Printer
Cleaning an Alps MD1300 print head
Does anyone know a way to "clean" the Alps micro-dry print head?
  • 83 Answers
Use a cotton swab and alcohol and gently rub the print head element.
Posted on May 01, 2010
How to clean head alps 1300
Use a cotton swap and isopropyl alcohol to gently clean the print head. The process is described in the user guide for the printer. If you don't have one, join the ALPS Yahoo Group and you can find one in the file section for download.
Jun 24, 2012 | Alps MD 1300 Thermal Printer
I have a 1 pixel line through the text every 3/8"
It could be a couple things. First try cleaning the print head as described in the ALPS manual (a cotton swap and alcohol). There could be some old ink stuck to the print head. If this doesn
Feb 24, 2011 | Alps MD 1000 Thermal Printer
When i try to print a photo i get white stripes across the photo. I bought a new ink cartridge but it didn't help.
White stripes across a print-out usually indicate clogged printer heads: look at your user manual on the cleaning procedures.
You can try cleaning BOTH the Black and Color cartridges heads by gentling cleaning and wiping the heads with clean moist tissue paper/kitchen paper. Also clean and dry the contacts (eg. copper looking printed circuit).
For bad and very dirty print heads, I also use a warm shallow dish of water and wash the head only and then dry off with clean tissue paper.
After re-inserting the cartridge, I suggest that you do a cleaning cycle and alignment and do a test print to ensure that the printing is back to normal.
Hope it helps: let me know how you go.
Dec 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
If the lines are horizontal, it might be a bad print head. If the lines are vertical is could be a dirty print head. In any case, try a good cleaning as outlined in the user guide.
Oct 26, 2010 | Alps MD 5000 Thermal Printer
Band printing
Hi There
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Alps MD 5000 Thermal Printer
My alps md 5000 doesnt seem to be printing decals as clear as it
these printers are flaky. There is a reason why the mainstream never picked ALPS up. The image quality stinks and the printer break down constantly. Koolaid drinkers in search of the grail love them.
Oct 28, 2009 | Alps MD 5000 Thermal Printer
Epson 9600 print head missing numerous nozzels during test print procedure. Tried power clean several times. Do you have a remedy?
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Jun 10, 2009 | Epson Stylus Pro 9600 InkJet Printer
Lines in the printing
Join the Yahoo Group for Alps printers. There is a lot of information there. Have you cleaned the print head? Refer to the Users Guide for how to do it. Lines in the printer output can indicate a bad printer head.
Mar 11, 2009 | Alps MD 1000 Thermal Printer
Alps MD 1300 Thermal Printer Logo
355 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
