Question about Whirlpool LER4634J Electric Dryer
Whirlpool LER4634EQ When I press the start button the dryer will not turn on. Dryer works great otherwise.
  • 1 more comment
  • kgutierz Dec 22, 2008
    Yes, it worked great. Only problem is that the start button just hums, does not turn dryer on. also, trying to get start switch out and it is not coming out.
    It's hard to tell now that you mention it. I just here humming when I press the start button. The dryer is only 4 yrs old, just it have died already ? Why wouldn't the switch go out ? I appreciate your help, thank you.
  • Kelly  Smith
    Kelly Smith May 11, 2010
    do you mean the dryer did work great until this problem?
  • 20 Answers
Ok is the humming coming from start switch or from down near the motor? usually it inst the start switch because the switch is so very simple of a component nothing goes wrong with it. kelly
Posted on Dec 22, 2008
  • Kelly  Smith
    Kelly Smith Dec 22, 2008
    the switch doesn't making any noise. it is your motor, i am so sorry. replacing a motor can be tough, but you could do it. a new one costs about $100 of so. if you do i can walk you through it. kelly P.S. try spinning the drum, hold down the door switch and then push the start button and see what happens.
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer won't work after pressing start button
the belt has broken off. the belt tensioner has a pulley too that will need to be replaced as well
Sears does sell the two in a kit form
Jun 16, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634EQ, when I press the button to turn dryer on it doesn't kick in, won't turn on. but you can hear the timer humming on the temp dial. Dryer was working perfectly. Is there a fuse in those...
yes, it sounds like you blew the main dryer thermal fuse, easy fix. write down the model number and go and buy one were ever. it will be white plastic with two metal tabs coming out of it. it might be skiny or it could be a round one no bigger then a half dollar. write me back once you have this. kelly
Dec 22, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer (electric)
did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Oct 04, 2007 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
180 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
