Question about Compaq Celeron A , 1.2 GHz (253775-B21) Processor
Beep Codes Having a problem. I continue to have audio sound 1 short 2 long in beeps. This is a new computer for me, and I dont know much about it.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    After the computer is running and booted or shortly after turning it on?
  • 15,935 Answers
Thats usually RAM failure. Remove, re-seat, and re-try. If still no, replace memory module.
Posted on Dec 22, 2008
    President:
  • 1,179 Answers
This code is telling you that there is either a problem with the graphics card or RAM. Try reseating the card & RAM. If this does not work remove and replace the graphics card. Reboot. Hope this helps.
Long beep on gateway computer
pls find the model no. and find the beep codes and match the order to identify the problem
ex:POST Beeping Error General Codes
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
Nov 07, 2016 | Gateway Computers & Internet
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
When I turn on my computer i hears a few double beeps and I don't see anything on my monitor while computer sounds like it running
Here is a link for with some information for the GA-M55plus-S3G motherboard:
http://china.giga-byte.com/FileList/Manual/motherboard_manual_ga-m55plus-s3g_3.x_e.pdf
The below was taken out of the document:
The beep codes below may help you identify the possible computer problems. However, they are
�� AWARD BIOS Beep Codes
Jul 07, 2009 | Gigabyte GA-M55plus-S3G Motherboard
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
Standard Original IBM POST Error Codes
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
Beaping Sounds When turning PC on
These beeps sound exactly like that of the RAM. If you are not too skeptical about going inside your PC, you can simply remove the RAM and reseat it back firmly. Sometimes this happens that the memory loses good connectivity and would just need a reseat.
Thanks,
Lolita
Mar 02, 2009 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Beeps
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Compaq Celeron A , 1.2 GHz (253775-B21) Processor Logo
129 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
