Question about Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater
Natural Gas wall heater
I have a natural gas wall heater, 65"high and 16" wide, it runs for about 10 minutes and shuts off.?? can you help, Thank You>.. I have a 30,000 btu Glo warm wall pack (13 years old ) the pilot lite will not stay lit one the system cycle . if i clean it it will work for a few days then strt to go out .
any idea's on how to fit it .
i have changed the thermocoupler last year helped for a week .
    Scholar:
  • 75 Answers
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Posted on Dec 22, 2008
Desa Natural Gas Wall heater 18,000 BTU
Hi i think you a right on the money with the pipe.
It could just be that their is a build up of dust causing the problem as this can happen if the unit hasnt been used often let me know how often its used and also the age thanks
Dec 14, 2007 | Tower Desa Natural Gas Heater - 25,000 BTU
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Btu rating on natural gas meter
Gas meters are usually rated in cubic feet per minute (CFM) not BTU. there are 1027 BTU per cubic foot so do the math. Try the link below Btu rating on natural gas meter
May 14, 2014 | Rheem EcoSense by 7.4 GPM Tankless Water...
Heater runs about 1 minute and shuts off
high limit switch is open. it will open it water inside header gets over 135 degrees, or you have a faulty high limit switch
Mar 26, 2014 | Pentair Sta-Rite Max-E-Therm 400 BTU...
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
May 16, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Is it normal to run a 16" vertical tie in to a horizontal exit
No, Exhaust vents on heaters should always maintain vertical orientation because heat rises and creates a natural drafting drawing the fumes out. You have a monoxide poisoning situation otherwise.
Oct 20, 2009 | Mr. Heater Natural Gas Garage Heater -...
53PVN shuts off after a few minutes
Yes and because it wasn't running clean the oxegen depletion sensor needs to be cleaned.
There is also small orfice on the burner that could also be dirty. If you are not very handy call a pro
Sep 08, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Is this a new unit or old? Does it have a fan or not? I need a little more info to walk you through this.
Dec 04, 2007 | Reddy R70ET Utility Heater
Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater Logo
1,005 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
