Question about Lanier 1205 Copier
PAPER JAM IN TRANPORT
THIS ON A LAINER LD032C:
AFTHER EVERY 100 COPY I GET A PAPAER JAM IN THE TRANPORT,BE FOR IT BEFOR IT GO TO EXIT.
    Novelist:
  • 158 Answers
IF THE PAPER IS LAYING FLAT ON THE TRANSPORT WHEN THE JAM OCCURS, THE PROBLEM MAY BE A DIRTY TRANSPORT BELT SENSOR. A TECHNICIAN IS REQUIRED TO REPAIR THIS, AS IT INVOLVES DISASSEMBLY OF THE IMAGING UNIT.
Posted on Jan 01, 2009
My copier canon ir2525 legal size paper jamming problem half paper exit unit out half paper exit assembly in A4 size and A3size 100%perfect exit plz solution this problem
Most common jam problems are caused by using thin paper 80g density or less. Recycled paper is the worst as it tends to tear easier as the their is only 20% new cellulose fibre in it and 80& is paper mache'. When using recycled paper, use min 100-120g weight papers and your jams will disappear.
May 29, 2015 | Canon Office Equipment & Supplies
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Apr 02, 2012 | Toshiba Office Equipment & Supplies
Our HP L7680 keeps telling us there is a paper jam...and there for will not let us copy etc. There is no papaer jam?
Unplug the power, open up all the covers and make sure there are no foreign objects (even small peices of ripped paper).
Close everthing up and power on.
If the message persists, there is a sensor problem
Mar 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
My printer is jamming paper
try using a heavier, better quality paper, or 80gsm paper, also try anning the papaer before loading, ie seperate the pages beofre loading the tray.
Mar 21, 2010 | Computers & Internet
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
126 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
George Mclaughlin
Inky Fingers
Inky Fingers
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
