Question about Kenmore 63074 Top Freezer Refrigerator
Kenmore 106.8562780 refrigerator just stopped today
Our refrigerator just stopped today. I actually noticed when I took the Ice Cream out and it was almost liquid. Most everything is still cold, yet it should have kicked on. Where can I find the fuse for this unit? I've had it apart, vacuumed underneath so I could look around. Please help.
Thank-you!
Rob
  • Kelly  Smith
    Kelly Smith May 11, 2010
    ok how bad was the dust in the coils underneath the refrig.? kelly
  • 183 Answers
SOURCE: Freezer is over-freezing
Change defrost sensor. Regards Advisor
Posted on Aug 23, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
  • 161 Answers
SOURCE: Replaced Start Relay because it was clicking...now?
If you are sure you have the right start relay, and are positive the start and run connections are correct, the compressor may be bad. There is an internal overload/overheat thermostat inside the compressor. If the motor windings are partially shorted out it will run for a little bit then stop. It will probably start after several hours when cooled down. The other possibility is that you have the start and run terminals reversed. If the start winding can't kick out after a few minutes it will overheat. As a final test, disconnect all wires from compressor. Plug in the box and turn it on. Make a test cord with a plug, wire and some alligator clips. One clip on one side and two clips on the other pole. Single clip goes to the common terminal, One of the other goes to the run. The last one is briefly touched to the run terminal. Just keep it there long enough for the compressor to start then remove it. Let it run for a few hours. It should cool the box down completely. It will run until you stop it as it's not using the thermostat in the box. If it works this way replace the relay again. If it stops by itself the compressor needs to be replaced. This is almost never worth it to fix.
Posted on Jul 03, 2008
  • 2335 Answers
SOURCE: kenmore elite refrigerator
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
woodchuck789
  • 4070 Answers
SOURCE: Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jan 26, 2010
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I am not sure what model # I have but it is a GE Profile. From the thermometer I have in there it says the freezer is -10 C but ice cream is still mushy. The refrigerator is about 10 C so I know this is to...
Make sure all ice is completely off the coils. Then if it continues to build up ice or frost on the back, your timer , heater, or thermostat are out and will need replacing.
Jul 06, 2009 | GE GSS20IEP Side by Side Refrigerator
This is a simple question. What is the average
Not so simple actually. Depends for long lasting, deep freeze, meat ect you want 0 to -4 Farenheit. For Ice cream (non-defrosting) soft 20 to 24 degrees firm 15-19 degreees, hard same as meat. For defrosting models stick with the 0 to -4 as otherwise ice cream and other liquids will actually melt during the warmest part of the defrost cycle. I believe that is a self defrosting model so I'd stick to 0 degrees farenheit average.
May 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrig freezer is not totally frozen, 9 years old Kenmore
its sounds like the automatic defrost system is starting to go bad est 150. to 225.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer way too cold - ice cream hard as a rock
The freezer may get as low as -18 degrees F or 0 F this is the point when life and bacteria stops growing.
Ice cream shouldn't be that cold unless it is whipped with air.
Feb 27, 2017 | Kenmore Refrigerators
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 63074 Top Freezer Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
