Question about Pioneer DEH-P6500 CD Player
Stereo quit putting out sound
I installed the pioneer deh-p6500 in my 1989 dodge ram van and the first 2 times that i started the van, the sound was excellent. the 3rd time all the lights came on the display, but no sound. if i turn the volume to max, i can barely hear sound. did i hook something up wrong or did the stereo burn out?
  • 15,935 Answers
If it was working, then stopped, it may be a grounded speaker or speaker wire. If a speaker is blown, you may have damaged the internal amplifier. It will need repair.
You may have just hit a tone adjustment button like FIE or EQ where the settings at each frequency are changed based on the source you are listening to. If its not a big deal, pull the radio fuse and wait 5 minutes... or locate the reset button - usually behind the faceplate and start from scratch. This way you will know it wasnt a button pressed on accident
Posted on Dec 22, 2008
NO SOUND OUT OF NEWLY INSTALLED PIONEER DEH-X6600BT
Did the Durango have the Infinity sound system? If so, there is a separate amplifier that is probably not being activated. Look for a blue or blue/white wire on the harness adapter and connect it to the Pioneer's blue/white wire. If it does not have blue/white, use the solid blue one.
Dec 29, 2013 | Pioneer Deh-X6600bt Car Cd Receiver...
Set time on Pioneer DEH-P4400
Press FUNCTION to select the time.
Press FUNCTION until the time appears in the
display.
2 Select the portion of the time display you
wish to set with 2/3.
Pressing 2/3 will select a portion of the clock
display:
HOUR-MINUTE
As you select portions of the clock display the
portion selected will blink.
3 Select the correct time with 5/?.
Pressing 5 will increase the selected hour or
minute. Pressing ? will decrease the selected
hour or minute.
http://www.generalmanual.com/Players/Pioneer-DEH-P4400-Single-CD-Player.htm
Dec 06, 2010 | Pioneer DEH-P440 CD Player
97 dodge ram 2500 van doesn't shift on time from 2nd to 3rd and 3rd to 4th.
it could be any number of things, i would try having the transmission serviced first. the transmission filter could be getting clogged making it work harder and therfore making it shift differently.
Jun 21, 2010 | 1998 Dodge Ram
I just hooked up a pioneer deh-5100ub stereo in my 2004 dodge ram 1500 pick-up using a store bought wiring harness but I cannot get any sound from my speakers now.
Does you truck say Infinity anywhere on a door panel or such? If so you need to make sure that the blue wire from the store bought wiring harness is connected to the amp turn on from the pioneer.
Mar 02, 2010 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Sprak plug Wires Need To Be Installed Correctly
You have several RAM sub-models in here:
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} B1500 RAM Van
B2500 RAM Van
B3500 RAM Van
RAM 1500 1/2 ton 2WD
RAM 1500 1/2 ton 4WD
RAM 2500 3/4 ton 2WD
RAM 2500 3/4 ton 4WD
RAM 3500 1 ton 2WD
RAM 3500 1 ton 4WD
Chrysler Full-Size Trucks 1989-1996 Repair Guide
To avoid confusion, remove and tag the wires one at a time for replacement.
Fig. 1: 2.5L 4-cylinder Engine. Engine Firing Order: 1-3-4-2. Distributor Rotation: Clockwise
Fig. 2: 3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise
Fig. 3: 5.2L and 5.9L V8 Engines. Engine Firing Order: 1-8-4-3-6-5-7-2. Distributor Rotation: Clockwise
Fig. 4: 8.0L V10 Engine. Engine Firing Order: 1-10-9-4-3-6-5-8-7-2. Distributorless Ignition
Hope helped with this (remember rated this help) Good luck.
Nov 06, 2009 | 1996 Dodge Ram
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
Need to wire it into dodge dakota
you will have to check with a radio dealer to get the correct "pigtail" to install that into your Dakota..and also the dealer can tell you if it is compatable with your Dakota..i hope this helps
Apr 26, 2009 | Pioneer DEH-3400 CD Player
Pioneer DEH P6000 screen reads "tuner er"
try disconecting your battery while its on then reconnect
Jan 01, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Pioneer DEH-P6500 CD Player Logo
266 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
