Question about GE Refrigerators
Water dispenser not working; lower half of fridge freezing.
We recently bought a previously owned house that came with a 5 year-old, side-by-side GE Refrigerator (Model #GSS 20/EMA WW; Serial # FA 226 550). The fridge is equipped with ice and water dispensers but we have had it set to the water dispenser only. The fridge worked fine until we had a 9-hour power outage in the area about 15 days ago. Soon after we noticed the water dispenser did not work – no water was delivered from the spout. The Owner’s Manual suggested that at installation “there might be air in the water line system” and suggested to “press the dispenser arm for at least tow minutes to remove trapped air from the water line and to fill the water system.” We did this a couple of times but to no avail and are concerned repeating the procedure might affect the pump in the fridge.A few days after the power outage, we have noticed vegetables were freezing in the two crispers at the bottom of the fridge although temperatures seemed normal in the top half. After noticing the vegetables frozen, we adjusted the temperature on the “Fresh Food Setting” from 5 to 4 and reduced the temperature setting on the “Deli Fresh” crisper from “middle” to “warmest.” Neither of these adjustments improved conditions in the fridge. Since then, we have incrementally reduced the he temperature on the “Fresh Food Setting” from 4 to 2. There has been no improvement and now things are freezing on the first shelf above the crisper bins. We put a thermometer in the fridge and found that the temperature at the top was +7C and at the bottom -5C. As far as we can tell the freezer side is working normally. Is it possible the two problems are related? In other words, is the water line to the dispenser frozen because the fridge has cooled down?Is there a reset “switch” or button that will restore the fridge to its normal operating mode?Any information you can provide would be greatly appreciated. Thank you in anticipation of your help.Brian and Sandra WikeemBowser, British Columbia, Canada
  • lecdung Jan 23, 2009
    Same as described, water reservoir bursted due to froze up ,also water line thru freezer door froze , no water at dispenser ...
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
rickzilla
  • 706 Answers
SOURCE: Water dispenser frozen?
I'll take a stab at helping you.
Most, if not all freezers have a small heater element that keeps the water inlet to that freezer compartment from freezing and if that's defective ( or unplugged ) then any incoming water would freeze before being dispensed or fed into an auto ice maker tray.
The freezer compartment being 'too cold' should not effect water flow if that heater was operational, however it may allow too much cold air to pass into the refridgerator area causing some food to freeze.
It's a good idea to keep the coils clean and dust free as a general rule of thumb but those are used as part of the cooling system to draw heat out of the freezer/fridge area but that doesn't seem to be your problem. Hope my comments help !
Posted on Aug 06, 2008
rickzilla
  • 706 Answers
SOURCE: water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Posted on Aug 14, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Underneath the crispers is full
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
How do you fix the water dispenser on a GE side by side refrigerator model GSS201EPD WW
Here are a couple of possible problems. Most common one is a defective water inlet valve. It is the plastic assembly at the lower back area where the house water connects to. On dispenser systems it is actually 2 valves in one unit---half lets water in to icemaker---the other half lets water dispense at door. It is electrically operated so if half goes bad , the other half can still work. If bad it needs replaced as a complete unit.
Second possible problem with some GE side by side models is they had problems with the water line in the door going to the dispenser sometime would freeze up. They came out with a heater kit that needs installed in the dispenser area to defrost the water line. Call GE service with your model number and they may be able to tell you if you need that kit installed.
Jun 28, 2015 | GE Refrigerators
Refrigerator temperature shows 60 degrees but waterline is freezing
yes thermastat maybe bad check sencer for temp it maybe bad
Aug 29, 2014 | Refrigerators
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refriderator about 3 years old. Recently the water dispenser stopped working, and the ice maker stopped as well. The ice maker seems to freeze up as it dispenses water in the tray to make ice....
Are you having any cooling problems whatsoever, anywhere? Is there any area in the unit that you dont put food for cooling reasons? if cooling is fine, check the water pressure as it comes into the refrigerator, you wil have to disconnect the water line at the solenoid valve behind the fridge. If pressure is good, pour 4-8 oz of water into ice maker, does it eject those cubes within 24 hours? then replace your water valve(s) One assembly houses a solenoid for both the ice maker and the water dispenser, both solenoids are bad.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
324 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
