Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother 5440cn print ink level device will not show on pc
In level device does not dispaly ink levels, when you click on ink level you get a no device display even though it was downloaded.
Also they are installed just to make you think your levels are low so you can buy more ink, The good ol Scam!!
Posted on Sep 11, 2007
    Genius:
  • 2,985 Answers
Nice to know what your ink levels are isn't it But these gadgets no matter which make of printer are software glitches that do a compute on the numbers pages printed its not like a fuel gauge in you car with a float in the tank. So don't worry too much about it.
SOURCE:
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
My status monitor says that all my colour supply levels are full. But the printer won't print in colour. Only black & white. Even when I choose the "print in colour" option. This hasn't happened...
Brother Inkjet printers' printheads are very sensitive, using non-genuine ink clots the printhead. Try to clean the head by pressing the ink maintenance button. Sometimes you need to clean several times.
Dec 11, 2009 | Brother MFC-5440CN All-In-One InkJet...
I am getting the unable to print Error 4F message on my Brother MFC 5440cn printer
Error 4F:
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
Piezoelectric (PZT)
ceramic actuator
defective
You need to replace the print head.
Oct 06, 2009 | Brother MFC-5440CN All-In-One InkJet...
How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Sep 03, 2009 | Brother MFC-9440CN Laser Printer
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
Ink Level
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.I hope this Solve your issueKhaled
Oct 21, 2008 | HP PSC 1600 InkJet Printer
Brother MFC-5440CN Ink Status
I have the same problem.I did go to Staples store and the person told me to clean the heads of the cartridges with alcohol and the bottom injector. I tried that and it did not work.It keeps telling me the ink is low even if I put in new ones. I am going to try the alcohol solution to see if it works. If not I will return to store for an exchange.I really like the printer.
Jul 24, 2008 | Brother MFC-5440 Printer
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Brother ink monitor not working
There could be a posibility that you may be low on ink. The reason i say this is that you say it prints green. Green is blue and yellow. That means that your red is empty or dried out. If you are low on ink you will have a low or no ink indication and sometimes the software for the printer only has 3-5 diffrent indications.What i mean is when you see the data for your ink there are diffrent levels that it shows. Your software may not be able to diffrenciate between the colors just the status of say one color in your case it could be red.Therefore it would read 0% of ink avaliable but still be able print green. If i were you I would buy a new ink cartridge and see if you get the same results.
Sep 19, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
459 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
