Question about Toshiba Satellite A100-S8111TD Notebook
Power issues in toshiba s1800-911
Because of nasty virus infection,toshiba s1800-911 was formated using xp pro bootable cd.But as startup files were loaded to the point of starting windows, the laptop just went off with no warning signs. I repeated the process again but it goes off much earlier at the point loading boot files. Everything else is just fine. Can someone help??
  • 837 Answers
Sounds like you have a problem with your power adapter, battery and or charge port ... I would suggest you let the unit "charge" overnight and try again.
Posted on Dec 22, 2008
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
Tip
Sign of a Virus Infected PC and How to Fix it
A computer virus is something that often interfere with your daily activities. Computer viruses usually spread unbeknownst to us, from one computer to another. One of media dissemination of computer viruses is via e-mail. After you run the attachment in an e-mail so sometimes you still do not realize that you're running is a computer virus.
What are the signs or indicators of computer viruses in your computer? Please just look at some of the following signs.
  • Your computer runs slower than usual and lasted consistently.
  • Computer suddenly stopped or not responding and it is often the case.
  • Computer suddenly restarts or crashes and this happened a few minutes.
  • Computer suddenly restart and could not walk normally again.
  • Computer application is not running properly.
  • Hard drive or disk drive is inaccessible.
  • Print activity is not working properly.
  • It often happens that strange error messages and do not usually.
  • Often visible menu or dialog box that is damaged.
The above is a common symptom that a computer infected by computer virus, but it can also occur due to interference with the hardware or software as well. The main solution is to install antivirus software that is always up-to-date.
Tips how to remove a virus that can not be handled Anti-virus
There is a very powerful tips to remove the virus, if the various Anti Virus that we use entirely powerless against it (probably only detect, but can not delete it). To do this would require a Bootable CD that contains a minimum of the File Manager program, such as Ultimate Boot CD, BartPE, and the like. Some programs are DOS-based and others are windows based. Or we could use a Linux Live CD, like Knoppix, Ubuntu Live CD and others. In General, the following steps:
  1. Find the location of the virus, especially the origin of the virus is running on your computer (the host)
  2. Once obtained, note (note) information such as file size, date (although the virus can change the size and date, but most always the same size and date. Can find similar files and recorded their location.
  3. Once obtained, use one of the Bootable CD and restart the computer to boot from a CD (you might need his first set its BIOS to first boot the CD / DVD-ROM).
  4. Open the file manager program, which is available. If using windows NT, XP or above, make sure the program supports reading NTFS format
  5. Find the file / virus and delete or if still in doubt, just rename from *. exe to *. VRS example. To convince, use the search facility to find files with the same size or nearly the same date. If found , you can rename it.
  6. Back restart the computer and check again
on Apr 17, 2010 | Computers & Internet
I WANT TO FORMAT MY TOSHIBA PORTEGE 7200CT LAPTOP TO WINDOW XP.HOWEVER,I DO NOT KNOW TO TO FORMAT
The instructions for this procedure are quite involved if you are talking about formatting and reinstalling the laptop operating system software. You need to have these things:
A Legitimate copy of the Operating system software on an official microsoft release CD that is bootable. Then you go to the bios in the startup usually by pressing the delete key while laptop is booting. then go to the boot proiority list and make sure the cd drawer is in the first option. Reboot the computer and then when the option to boot from cd comes up, press any key and it will boot from the cd.
Once the installation options appear, you need to select the hard disk to use and then select the format and install Windows XP. Select format using NTFS filing system and then the process starts to format the drive and install the file need to complete setup.
Once the GUI portion of set up installs and you have logged in for the first time, don't forget to change the boot priority back to the hard disk!
Hope this helps :D
Nov 23, 2010 | Toshiba Portege 7200CT Notebook
My System is affected by virus.when i format the total hard drive still it can run within some days.how 2 remove this virus manually or help 2 format the drive using any bootable software...plz...
I suggest booting from a bootable cdrom disk, instead of a floppy disk, USB drive, etc. Everything except the cdrom can quite easily become infected with a virus just by plugging it into the computer. You MUST create the bootable cdrom from a KNOWN clean computer! If you try to create one from the infected system, you can almost be assured you will only create an infected cdrom!
If you don't have a way of creating a bootable cdrom, try booting your system from your Windows installation cd / dvd. Do a complete format before the install and then SHUT DOWN the computer! Do NOT just reboot and continue with the installation of the OS. Viruses are "memory resident" in that they load themselves up into RAM when the computer boots and will remain there until the machine does a complete shut down. I recommend you shutdown (i.e., turn off the computer) and restart the machine a couple of times AFTER doing the format to be assured that the virus is eradicated.
Once you are satisfied the virus no longer exists, you can go ahead with a new install of the OS. The FIRST thing to do before loading ANY of your personal files back onto the computer is to install a virus scanning software -- and make sure it is active and the virus pattern files are current. After scanning the hard drive for problems and finding none, can you go ahead with the installation / restore of your personal files.
Chances are pretty good that the reason the computer runs OK for a couple of days and then the virus reappears is that a file you have installed or copied over from your backup is infected. Each time you launch the program / file, the virus gets installed and the cycle starts again.
Jan 23, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My laptop will start wil windows logo and then stops it is a p35-6111 toshiba satellite with xp pro any assistance would be appreciated aaron
The problem is due to System startup failure. It could be due to many reasons like abruptly shutting down the system, Services not starting, Malware or trojans infection, Corrupt Hard drive, corrupt system files,etc.
Method 1 :
Start your system by pressing F8 upon startup.
Select "last known good configuration that works"
Check it it can get you to your Desktop.
Reboot the system,everything will be fine.
Method 2 : Start your system by pressing F8 upon startup.
Select "Safe boot"
Check if it can get you to your Desktop.
Now, Click Windows startup button
Select "All programs"
Select "Accessories"
Select "System tools"
Select "System Restore"
and try to restore the system in an ealier point.
your system will reboot now and check if it works fine now.
Method 3 :
Download "Hiren's Boot CD"
Below is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Extract the zip file using Winzip or Winrar.
Burn the ISO image file with Nero or PowerISO in a CD.
Boot the system using that CD ( Set your BIOS to boot from CD-DVD Drive)
Select "Windows XP Mini" upon startup.
Use tools that are available in the CD
It will most probably solve your problem.
If the problem still persists Use can always Backup your important files using that CD to an external USB Drive or to any Network Share location.
That's it.
Jan 09, 2010 | Toshiba Satellite P35-S6111 Notebook
XP Doesnt get to log in screen
Try to repair the OS, if you have the installation cd.. or format it then install new OS...
Jun 24, 2009 | Computers & Internet
I have windows xp media center. my computer has been infected with some kind of virus. i have tried to reinstall my os but apparently the recovery partition is also infected and it will not let me...
You will need a bootable antivirus solution to clean the viruses off of the machine if it's that bad, or at least that is the easiest way I know of.
Look, here is the real deal, your PC when booted to the hard drive into windows OS has what are called OS protected files. That means that even the best scanner will not remove it totally from the machine while booted in Windows OS.
When you use a bootable AV solution it runs the OS from the CD, then when you are scanning the drive for those little nasties, it can be remove, because the OS on the drive is not protecting them.
However be aware when using this method, that any files can and will be removed!!! The way I look at it, if it's a virus I don't want it on my hard drive! period! Then once the virus is removed format and reinstall the OS. Sorry to hear about your Recovery Partition!
There are ways to make these yourself, but if you don't know what your doing, relax Bart has you covered!
Check that out, that should fix you up. Yeah I know this is not a free solution, but one I know will work!
Mar 10, 2009 | eMachines T5048 PC Desktop
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
