Question about Monkey Video MFDM84IR Car Monitor
I have a monkey 15'' lcd screen that has a 'S' video out.
How do I connect the screen to my player which has dual RCA connectors?
  • ricardoht69 Apr 19, 2009
    I HAVE A MONKEY LCD MONITOR (MFDM14) WITH 9-PIN S-VIDEO OUT AND MY PLAYER IS RCA HAVE INPUT
  • 15,935 Answers
Svideo to RCA adapter...
Can be seen here
http://www.svideo.com/svideorca.html
Posted on Dec 22, 2008
How do I connect a Emerson TV to a Magnavox DVD?
You will need either an S-Video connector and two RCA connectors, or three RCA connectors. Use either the S-video connector or one RCA connector to connect the video, and use the two RCA connectors to connect LEFT and RIGHT audio. Done.
May 04, 2015 | Magnavox Televison & Video
Menu screen wont come on
Check video connections first. If previously working, confirm screen is in proper setting to allow play. Get small TV with RCA Video connectors and connect your DVD to small TV to confirm you have video coming out of player. if no video then it's your player. Replace player! If you have video then replace screen
Jun 14, 2014 | Valor ITS-701W Car DVD Player
How do you hook up an mp3 player to insignia ns-r2000
You will need an Dual RCA to 3.5mm stereo cable. One similar to this: http://www.dcables.net/Dual-RCA-to-3_5-mm-Stereo-Cable-5-Feet.aspx
It would probably be easier to pick one up at your local Wal-Mart or Radio Shack.
Just connect the RCA connectors to one of the audio line inputs and the 3.5mm to your mp3 player. Set your insignia to receive the source you just connected.
Hope this helps
Apr 07, 2011 | Insignia NS-R2000
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
Jan 02, 2011 | RCA F25645 25" TV
I WOULD LIKE TO CONNECT MY LAP TOP TO TV WHAT CABLE AND HOW WOULD YOU DO IT ?
You will need
  • a PC or Mac laptop computer
  • a digital TV
  • a VGA 15-pin connector cable; or an S-Video cable and mini to RCA audio cable;
  • or a wireless converter
More information you can visit:http://www.videojug.com/film/how-to-connect-your-laptop-to-your-television.
If you need laptop accessories, such as Dell Latitude D620 Keyboard, toshiba a45 keyboard, gateway 450rog keyboard etc, you can visit www.udtek.com.
Apr 12, 2010 | Acer Aspire One AOA110-1588 Notebook
I WANT TO KNOW WHAT KIND OF CONNECTOR I SHOULD BE LOOKING FOR THE VENTURER DUAL LCD SCREEN.
need to know more of what you are doing but to connect a 2nd screen it normally on these a std audio lead with red/yellow white phono leads, and green/white power lead
Dec 06, 2009 | Pioneer AVICN2 In-Dash DVD Multimedia AV...
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Which channel do i put the tv on, and which do i put the dvd player on in order for them to work together? I have a sanyo flat screen tv and a sony dolby digital dvd player, and i don't know how to get...
You do not put your TV on any channel. DVD players need to connect to a TV with video cables and not a RF cable. This means 3 connection options on how your DVD player should connect to your TV. First, since your DVD player is NOT a bluray player, then HDMI connection is not needed. 2nd, the best choice would be component cables. These are the RED/GREEN/BLUE RCA connector that are on the back of your DVD player. They got into the input of your TV that has the RED/GREEN/BLUE RCA connectors. These are your video connector. Now, you need to connect the audio. Look for the RED/WHITE analog audio connectors out of your DVD player. Connector those to your AUDIO RED/WHITE input of the TV. Power on the DVD player and then power on your TV. Press the SOURCE or INPUT button on the remote for the TV until you see the DVD on the TV....The second option is the connect your DVD player up to your TV with composite video, YELLOW/RED/WHITE cable...
May 16, 2009 | Sanyo DP32648 32 in. LCD TV
Venturer dual screen dvd player for car
Hi and welcome to FixYa,
Initially, could be:
  • cable/connector problem;
  • 12VDC power supply/regulator;
  • monitor itself. Could be tested with another external video source and a shorter RCA to RCA cable.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Power Voice System Venturer 7" Portable...
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Monkey Video MFDM84IR Car Monitor Logo
120 people viewed this question
Top Monkey Video Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Monkey Video Car Audio and Video Expert? Answer questions, earn points and help others
