Question about Hotpoint Aquarius WMA42 Front Load Washer
Changing the waste pipe to a hotpoint dishwasher
I need to remove the waste pipe fully and relpace it with a new one but can not get it off at the back of the dishwaher where it is connected to the dishwasher, any ideas how to do this?
2 Suggested Answers
  • 130 Answers
SOURCE: need to remove drainage pipe, can't remove white plastic clip, is there a knack?
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any  foreign objects. The pump is usually at the back right side ( looking at the washer from the front ).
Posted on May 07, 2009
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
My hotpoint aquarius is leaving dirty residue after the full cycle - do I need a new dishwasher?
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jun 18, 2011 | Hotpoint Dishwashers
Backup of foul smelling water into the dishwasher
Outlet pipe is partially or completely blocked.
Use a dishwasher cleaner in it, but before you even do that, remove outlet pipe from waste pipe - and clear all the gunk out you can.
I suggest a bucket with disinfectant and washing powder to dissolve the grease.
You may need a drain cleaner down the waste pipe too - & flush with hot water and washing powder.
Aug 04, 2009 | GE Profile PDW8400J Built-in Dishwasher
Hotpoint dishwasher fdw60
the fault wasn't with the machine. we got new waste pipes put in and the conection for the dishwasher hose didn't have the hole for the water to release. thank you for your help
Jul 15, 2008 | Hotpoint Dishwashers
The waste pipe on my hotpoint dishwasher is connected to a spigot. I now want to buy a Bosch replacement but all models have a waste pipe which is too small in diameter to fit the existing spigot. A...
Do you have a garbage disposal? It is usually easier to drain through the garbage disposal. There is a fitting for this on all disposals. Be sure to remove the knock out plug first.
Jul 04, 2008 | Dishwashers
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Problemwith Hotpoint Aquarius FDW60
Eco light flashing, and refuses to do any of the other programs
Oct 15, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Sep 27, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dishwasher
you ..dont need to get into the back.With the bottom front panel off,disconnect the waste pipe frm the pump on the right and pull it through from its other end.
Sep 17, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Aquarius WMA42 Front Load Washer Logo
213 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
