Question about Whirlpool LER4634J Electric Dryer
Whirlpool LER4634EQ, when I press the button to turn dryer on it doesn't kick in, won't turn on. but you can hear the timer humming on the temp dial. Dryer was working perfectly. Is there a fuse in those dryers that could have blown ?
  • 4 more comments
  • kgutierz Dec 22, 2008
    Where on the dryer is this fuse ? Should I pull the back off of it ? I sure hope that this is the problem. I am a 60 yr old lady trying to fix my own stuff. Can't afford a repairman. Thank you so so much for your responses.
    So, you don't think that it is the motor ?
    I'll do that but I am confused. You thought it was the fuse, but now you think it is the motor ? I guess because of what I replied to, not sure which answer is first. I'm hoping for a fuse, ofcoarse :). A motor, I am not so sure I can replace. Might be better off buying a dryer off of Craigslist. Just don't understand why a motor would go bad in 4 yrs. I understand that you can only go by what I tell you.
    What would the symtoms be if it is just a fuse ?
  • Anonymous Dec 28, 2008
    whirlpool dryer just stoped coming on, i can here the timer click but nothing else. is it possible its the switch or the door switch and how do i check them with a volt meter.
  • KimOhio
    KimOhio Jan 03, 2009
    I have the same problem with LER4634EQ2. I can hear the timer ticking, but when I push the start button, nothing happens. I am going to get a new fuse and install it, and let you know what happens.
  • 20 Answers
Yes, it sounds like you blew the main dryer thermal fuse, easy fix. write down the model number and go and buy one were ever. it will be white plastic with two metal tabs coming out of it. it might be skiny or it could be a round one no bigger then a half dollar. write me back once you have this. kelly
Posted on Dec 22, 2008
  • 1 more comment
  • Kelly  Smith
    Kelly Smith Dec 22, 2008
    if you are lucky it is in the back. does your dryer have a back panel? if so it is back their. i have faith that you can do it, all you need is a 1/4 nut driver. just pull the dry out or tape the door shut and place some towels in front of the dryer and lay the dry face down. this way you can access everything you need to get at, just unplug first. kelly
  • Kelly  Smith
    yes, when you push the start button and you hear a hum it is the motor. do this, have someone else push the start while have your ear in the lower left corner in the front or in the lower back corner on the right. if you hear that humming right their then its the motor. kelly
  • Kelly  Smith
    Kelly Smith Dec 23, 2008
    oops, sorry if i said anything about a motor i am answering many questions. just keep to the advise about the fuse. kelly
Dryer kicks off after a few minutes
Does it stop at the same position on the dial each time..solution..replace/repair timer. Does it stop at different times..check your vent that it is clear.
Does it hum when you try to start it? Motor problem.
No response from dryer..check belt.
Oct 18, 2013 | Whirlpool Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer LGR 7646FQ1 simply does not turn on
I believe mine issue is the same....we isolated it to the timer itself.....try having everything set so it should be running, then slowly move timer around its cycles....mine would kick on an off with no rhyme or reason and when it should have been off.....timer shot, have ordered replacement.
Mar 31, 2009 | Whirlpool Dryers
Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Jan 04, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool LER4634EQ
ok is the humming coming from start switch or from down near the motor? usually it inst the start switch because the switch is so very simple of a component nothing goes wrong with it. kelly
Dec 22, 2008 | Whirlpool LER4634J Electric Dryer
Dryer won't run
Its time to call the repairman. If its the motor humming its either bad or the dryer is froze up and unable to turn causing the motor to hum. Eventually it will trip the breaker.
Nov 06, 2007 | Amana ALG331RAW Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
240 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
