Question about Microwave Ovens
How to change lightbulbs and how to get bottom off for cleaning
1. The lighbulbs have never been changed. one is out, and they both seem to have what appears to be glue at the base of each bulb. How does one remove these for changing?
2. I am trying to totally remove the bottom for cleaning. The screws are out, but the bottom is still on. How can I do this?
3. Finally, I would like to know if Goo B Gone can be used on parts to clean them,. It does say to use in a well ventilated area and not to use near heat or flames. What is your advice? Grease Removal?
The product IS valid, MH7140XFB over range microwave Whirlpool
  • stonebrook95 Dec 23, 2008
    Westinghouse 3501
    How to change light bulb ?
  • William Miller
    William Miller May 11, 2010
    The bulbs are often tacked in place with contact cement or hot glue,
    and sometimes there may have been enough moisture to corrode and seize
    up.
    You could heat them up
    with a hair dryer
    to loosen the glue.
    Please reply back with your brand and model number so we can help you further.
Model Westinghouse WST 3501 Micro wave
Not in your data base ?
"How to change bulb?"
Posted on Dec 26, 2008
  • Microwave Ovens Master
  • 9,149 Answers
Please unplug your oven before you remove or install bulbs!
The bulbs are often tacked in place with contact cement or hot glue,and sometimes there may have been enough moisture to corrode and seize up.
You could heat them up with a hair dryer to loosen the glue.
That usually works.
You can find helpful exploded view diagrams (and order parts if needed) by entering your full model number here.
These views will help you see how the oven comes apart.
Posted on Dec 25, 2008
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 10, 2014 | Kenmore Microwave Ovens
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
May 28, 2010 | Viking VMOR205SS Microwave Oven
HF87960GB Need to change lightbulb,how? Cant seem to locate it can anybody help please, Tony
on the top of the oven there is a plate with 2 hex screws, just undo these and your see a bulb and BINGO!
Oct 17, 2009 | Siemens HF87950GB Convection Microwave...
Emerson CDFL AR732 doesn't seem to be any way to change lightbulb.
there is always a way to change a light bulb, its only whats cheaper. The bulb or the oven?
Aug 11, 2009 | Microwave Ovens
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
I need to replace the light bulb under my advantium 120 but my wife threw the lighbulb away I need to find out what size lightbulb I would need
I would think that you can find that info either in the owners manual or right in the area where the light resides. Usually there is a sticker there with the info you need. Best wishes!
Jul 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
244 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
