EPUB format ereader books to be tranfered by way of a Sandisk memory stick to a SanDisk Micro SD card
You will need to connect your Kobo Vox to your computer
click start click on computer to open you should see your drives C: and your other drives cd dvd and your Kovo Vox drive E: or F:
it might be seen as a mass storage device
from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select
the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a
usb device
if you need more help with this post a reply
hope this helps
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: I purchased a 4GB Sandisk
your samsung Gravity 2 wont read the HC format, there is not much you can do sorry. the SD HC is a newer format for devices in the last year or so. Older devices will not accept the HC format cards. I did the same thing! And im in the business, easy mistake. Keep it around though you'll use it soon, just not in your Samsung. Gurvy
Testimonial: "thank you, I realize this was the case... in my opinion, the SD/HC card manufacturers should put a warning on the packaging. I did get my money back. "
