Question about Sony PlayStation 2 (PS2) Console
I dont knw whats wrong
I start the system ... the initial appears with incorrect or no sound and a series of dots behind the words... then the browser and sys config. screen comes up... no sound of course... and when i put in a game... the screen shifts onto darkness as it should but the darkness remains and game will not start... what do i do... plz help
    Problem Solver:
  • 12 Answers
I got it. The same thing happens to me. You should put the game in and if the browser and system configuration comes up click on the browser. If the game and the memory card show up click on the game. If just the memory card shows up it will say disc could not be read and i think the game might not work. But if you want to try to make the game work, put a little bit of soap on your fingers and cover the whole entire game with it, the run it under the water and make sure all of the soap is off. Then try the game. But if that does'nt work and you really like the game, clog up your sink with water and put soap on the game and then let it sit in the water for about ten minutes, if this does'nt work i dont think anything could make this game workd.
Posted on Dec 22, 2008
Black screen green dots
What was the last thing you did on your computer before this happened?
Did you change any system settings in the BIOS?
Did you add new software? or update any software or drivers?
Did you add any new hardware?
Is your system BIOS infected with a virus?
Because it appears that your PC is hanging up during the Power-On-Self-Test [POST]
Here's what happens; when the power is turned on, the computer BIOS [Basic Input/Output System] runs a POST (Power-On Self-Test). It is a diagnostic testing sequence that the computer runs to determine if the hardware [like the mouse, keyboard, hard drive, etc.] is working properly.
If the necessary hardware is detected and found to be operating properly, the computer begins to boot; If the hardware is not detected or is not operating properly, the BIOS issues an error message.
The error message may be a text on the display screen and/or a series of coded beeps, depending on the nature of the problem.
The series or pattern of beeps may vary...they may be in a number of long or short beeps or a mixture of long and short beeps, or even one long continuous beep, depending on what type of BIOS is installed.
Since POST runs before the computer's video card is activated or the integrated graphic chip on the main board, it may not be possible to progress to the display screen.
So if an error is detected during the POST it will halt the boot process because the hardware is essential for the computer's functions.
How many beeps do you hear during the initial POST?
You may have a burned out video chip/card; or corrupt drivers; or even an IRQ [Interrupt Request] conflict.
Nov 26, 2013 | Acer Computers & Internet
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
BSOD constantly comes up on Dell Latitude D600 with several different error messages. Is this common with this laptop?
On the dell screen press f12 run the diagnostic option if anything fails replace that part. If nothing fails try system restore or just reload the computer with the operating system disk
Feb 18, 2012 | Dell Latitude D600 Notebook
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif ESS NVM Initialization caution.gif CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
I have an EVEREX laptop and the number lock is on i cant turn it off is there any way i can turn it off?
Try rebooting - that should shut it off - if you're looking for another solution, try this..
  1. Begin by first clicking on the Start Button.
  2. Then click on the Run Icon, which will open up the Run Menu for you.
  3. Type the word: Notepad into the white area and then click on OK.
  4. This will open up the Window’s Notepad Utility.
  5. Then click on the word File, which is contained in your top tool bar area.
  6. This will pull down a menu for you to now click on Open.
  7. In the File name: area at the bottom of the screen type in: C:\CONFIG.SYS
  8. Then click on the Open button on the right side of the screen.
  9. Now add a line that reads: NUMLOCK=OFF into your CONFIG.SYS file.
  10. Then save your changes by clicking on the word File again in your top tool bar area.
  11. This will pull down a menu for you to now click on Save.
  12. Then exit Notepad and reboot your computer for the changes to take effect.
  13. Note: The line: NUMLOCK=ON can be substituted if you want your Numlock always on.
..good luck!! Hope this helps!
Sep 12, 2009 | Everex StepNote NC1500 Notebook
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
My Dell computer keeps putting up a message saying that "it failed on loading skin name "minibcont".It says to check the skin name in my config.file or reinstall the application. Anyone know what this...
What operating system?? It sounds like a program that was not un installed right or is damaged Try and find the program using windows search and reinstall it You can also use windows help and support solve a problem it will tell you how to change your config.sys file Make sure you backup and set restore before making changes to config.sys. Please rate me mysleuth
Mar 29, 2009 | Dell Inspiron 530 Desktop Computer
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
Sony PlayStation 2 (PS2) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
