Question about RCA Televison & Video
Original remote lost. It is a RCA TV
We go to menu and it will not let us arrow down. so we can not program the channels in. the channels are stuck on air. my daughter had satilite dish and we have cable.. we bought a RCA Remote. would you be so kind and help us out Thank you. Sally. It has a beautiful picture. It is a TV AND VCR COMBO the vcr doesn't work .But that is ok. We don/t need the vcr.
    Top Expert:
  • RCA Master
  • 12,962 Answers
To get full functionality you need to get the oem remote since universals have limited, very basic functions and most do not include menus, input selections, etc. Enter in to ebay the exact model of your rca - very often the sets are there and more often than not remotes are also available!!!!And if you cannot find one, the Harmony line of remotes, not cheap, are very comprehensive in their controls.
eBayeBay
Posted on Sep 22, 2017
SOURCE: DAEWOO TV/VCR COMBO DVQ 14H1FC LOST REMOTE
Hi, Sometimes the universal remotes are tricky.  If you don't purchase one that is specifically recommended by the manufacturer, you won't get full functionality.  Here is a generic that is "replacement" for that remote: http://www.daewoo.newremotecontrol.com/catalog_item.php?catnum=48B4139A02
Here is another place that has the replacement and an alternative: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12257602513440&smodel=48B4139A02&brand_pn=DAEWOO_48B4139A02
Hope this was helpful, have a great day!
Posted on Nov 04, 2008
freetek
  • 5569 Answers
SOURCE: programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Posted on Dec 18, 2008
SOURCE: DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
Posted on Dec 28, 2008
Shuttle83
  • 1139 Answers
SOURCE: how to disable the vcr on emerson dvd vcr combo?
Hello sjz4923,
I understand your frustration, however you are not going to want to hear this so what I'll do is just come out and explain why what you are asking is almost impossible, and I'll offer a solution that will help you possibly repair this problem.
The term tv/dvd/vcr combo is a misnomer. The term implies that there are three components in this TV set (TV, VCR, DVD) when in reality there are 1 and 1/2 components in this unit. The TV section of this set is actually the VCR section (RF tuner, IF processor, Video and audio, sync section) what is added to make the TV part of this is the deflection, and High voltage section to power and control the signal to the CRT. As far as the DVD section this basically is a DVD player without the video output, but rather the analog video plugs into the VCR video out. You do have aux ports for DVD video out but these may or may not be amplified video. In a nut shell The TV and the VCR are the same electronics except for the deflection and HV circuits, and the DVD and VCR are separate except for the audio and video main inputs.
So what you are asking is almost impossible since the TV and VCR are the circuit.
Now to repair your problem. What is happening is that the signal that the circuit uses to tell that the VCR carriage is connected properly is not being sensed, what this could mean is the the signal processor is bad or the position control is malfunctioning. The first thing I would do is to make sure that the position control (a wheel on the circuit board which the carriage sets on top of and a peg from the carriage sets into a hole on the wheel) is in sync with the carriage wheel.
Also if you have the equipment you can check the sync signal created by the control and compare it with the signal on the schematic of the TV.
Now having said all of this, if you don't have a background in electronics I would suggest that you get a TV repair technician to work on this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 26, 2009
SOURCE: daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Posted on Feb 19, 2009
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Channel selecter
With a universal this is quite common-- not all remotes that will program for a set will have all the same features the original remote had.
Jun 16, 2012 | RCA RCR312W Universal Remote Control for...
My RCA truflat is stuck on MONO, I have lost the remote ..how do I get it off of MONO?
Push the tv menu button on the front of the tv set.Go to Audio setup used the channel buttons UP and DOWN to pick ur choice.Can't do this manually.Try website like Remotes.com to buy an tv original remote.
Aug 08, 2011 | RCA TruFlat 27F520T 27" TV
Tv is not working it is stuck on channel 3 and stays there and need it to go on output in front and can't watch any channels with direct tv satalite very difficult lost remote and need code this tv and...
Hello
If you have its original remote control you can unlock its parential settings and reset it. Then only you can watch other channels also. I'm ver sorry to say that if you lost your TVs remote control, you will be unable to unlock it. Try to get a remote from any of your friends who owns the same model number RCA TV. If you are able to get it, do the following with that remote, and reset the V-chip. Try to purchase one new remote control from RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK
Happy New Year
Dec 31, 2010 | RCA TruFlat 27F520T 27" TV
I lost the remote i bought n rca programmed tv only works with volume and channel changing. i have cable and i want to add channels. i need to access the menu
U can't access menu of the tv with the univeral remote.Only with the original remote.Try website like Remotes.com to buy an original remote.
Oct 02, 2010 | Televison & Video
We cannot tune our Wega TV
Here's the procedure:
  1. Press MENU.
  2. Press LEFT ARROW to highlight Channel Menu.
  3. Press DOWN ARROW to highlight Cable. Press CENTER BUTTON to select.
  4. Press DOWN or UP ARROW to highlight On or Off according to how you connected your TV. Press CENTER BUTTON to select.
  5. Press DOWN ARROW to highlight Auto Program. Press CENTER BUTTON to search for channels.
  6. After Auto Program finishes, press MENU to exit.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Dec 03, 2008 | RCA Televison & Video
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
Programming
You need the original remote to change anything in the menus of the set. With a universal remote, you can manualy change the channels, but you cannot sequence them or change any of the setups to have them work automaticaly.
All TV manufactures are like this.
Call the authorized service rep, and order a new remote, or find the original if you want to be able to use your set properly. Don't accept a universal remote, because this will not properly resolve your issue.
Jerry G.
Jun 29, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
