Question about Pioneer VSX-D508
TV/SAT audio input is inop
I have my video and auto output of my cable box hooked to the tv/sat input of my vsx-d508 receiver. The video comes through, but not the audio. If I hook the output of the cable box to the dvd input of the receiver, video and audio both work. So the question is this: is the tv/sat audio input broken?
Thanks to anyone who can help.
techman
  • 3130 Answers
SOURCE: TV/SAT Video channel went out - Pioneer VSX516
Double check the video connection cable directly out of the SAT reciver and the video cable out from the Pioneer reciver, as there maybe an intermittant connection in them. If you replace them or sub them for known good ones, and you still have this probem, there is a switching IC inside the pioneer that has to be replaced.
Posted on Jan 05, 2007
techman
  • 3130 Answers
SOURCE: Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Posted on Jul 30, 2007
welcomejee
  • 10594 Answers
SOURCE: No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Posted on Sep 15, 2009
  • 3247 Answers
SOURCE: I have a new LG 42LD520 LCD TV which I'm trying to
Normally the LG TV Optical output will require an optical cable and not a PCM. So I am not sure if you are connecting the correct cable. The Pioneer can take both input types but the LG TV will only provide Digital output in Optical connection. PCM is a co-axial connection.
Assuming you have the correct cable you will need to assign the correct input types in the Pioneer receiver by selection using the setup menu. Do you have the user manual for the Pioneer receiver?
Posted on Nov 28, 2010
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
How to hook up a denon avr -1706 receiver To a lg smart tv
If you are tuning in TV stations with the TV set, you will need either an optical or a coaxial audio cable to go from the digital audio out of the TV to a digital audio in on the receiver. This setup should give you 5.1 Dolby digital sound. You can also use a pair of red and white rca cables, but you will only have 2 channel sound. You may need to set the TV to output the audio to external speakers. You will need to set the receiver to the input the TV audio is connected to.
If you want to watch Sat or Cable, you probably need a couple of HDMI cables. One HDMI cable will go from the output of the Sat/Cable box to the appropriate HDMI input on the receiver. The second HDMI cable will go from the Monitor Out on the receiver to an HDMI Input on the TV. You may need to set the receiver to output HDMI audio from the receiver, and not the TV. You will need to set the TV to the HDMI Input you connected to on the TV. You will also need to set the receiver to the input the Sat/Cable box is connected to.
Details of both of these setups should be covered in the receiver and the TV manuals. Refer to them for the detailed connections and settings you need to make.
Good Luck!
Mar 02, 2015 | Denon Audio Players & Recorders
How to run tv from sat box and not have to turn on the reicer all the time. When I do want surround use the digital audio off sat box. Yamaha RX V377
If your SAT Box has multiple outputs, hook the HDMI output to your receiver so you can get full surround on movies etc. Connect the HDMI out on your receiver to an HDMI input on the TV. Run a composite or S-video connection from the sat box to the TV for regular TV viewing/listening without the receiver & speakers. I don't think you can get full HD over either of these cables, but you may be able to use the composite connections if they are available on your sat box and TV.
Jan 16, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Tv/sat output on my reciever does not work
Make sure your audio input for TV/Sat is set to "Auto" If you have video passing to your TV from the receiver its a lot easire to navigate sony's GUI menu (main Menu) if not, run a basic video cable from the "monitor out" of the receiver to a video input on the TV. Then, using the sony remote press "menu" toggle thru the screens until you find "Audio" look for "input" then TV/Sat then set to "Auto"
I'm pulling this from memory, so if you still have an issue, please post a reply and I'll pull the manual and help you further.
Oct 04, 2010 | Sony STR-DE885 Receiver
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Sep 15, 2009 | Pioneer VSX-D509S Receiver
Hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
Aug 08, 2009 | Pioneer VSX-D509S Receiver
Durabrand dvd/video combi
There could be at least two ways to hook in your VCR. The common way is to hook your VCR inline (between) the sat box output (RF or antenna) and the TV RF/antenna input. This will allow you to play the VCR/DVD & record whatever channel the sat box is set to. I'm not real familiar with the newer sat boxes, but I assume they output one channel at a time, thus, you can only record that channel. On the older cable or outdoor antenna systems, you could record one channel while watching another. Perhaps some sat boxes have this capability. You might do a Google search with the box Model number to see if an online manual can be found. The other hookup possibility is if your TV set has audio/video inputs & outputs. Hook these to the matching input/output of the VCR/DVD.
Sep 30, 2007 | Televison & Video
Pioneer VSX-D508 Logo
90 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
