Please define reboot. Do you mean it keeps powering on and off displaying the Garmin logo or does a window pop up saying it is powering down in 30 seconds? Did this happen after you tried to update the firmware or map?
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices. You need to go with microSD cards, 2GB and smaller.
Please follow the instructions below to remove the "Loader Loading" message from
the unit.
To fix this problem on
Windows:
With the nuvi powered off, press and hold the upper left hand corner of the
touchscreen with your finger
Continue to hold the touchscreen while pressing and releasing the power
button on the device. The Garmin Logo should display
Continue to hold the touchscreen whileconnecting the device to your
computer
After 30 seconds, the screen should flash white. At thispoint,
release the touchscreen.A green progress bar should display on the
device. After the progress bar completes (45-60 seconds), the device should go
into Mass Storage mode
Open the nuvi drive that appears in My Computer or Computer
Locate the Voice folder and delete the extra Voice files that are not needed
Type ".System" (without quotations) after the nuvi's letter in the address
bar
For example, if your nuvi appears as E:\ then after typing ".System" in the
address bar, it should look like this: E:\.System
Locate the GUPDATE.GCD file and delete it
Safely remove your device from your computer
After the corrupted update file
has been removed, the device should work properly. Run the WebUpdater program to
update the device's operating software.
To fix this problem on a
Mac:
Continue to hold the touchscreen while connecting the device to your
computer
After 30 seconds the screen should flash white. At this point, release the
touchscreen. A green progress bar should display on the device. After the
progress bar completes (45-60 seconds), the device should go into Mass Storage
mode
Open the nuvi drive that appears on the Desktop
Click the GO menu at the top of the computer screen
Click Go to Folder
Type .System
Click Go
Locate the GUPDATE.GCD file and move it to your trash
Empty the trash
Eject the nuvi from the Mac
You need to press and hold the bottom right corner of the touch screen BEFORE you turn the power on. You only stop pressing when the reset menu appears.
Try a hard reset,the Hard
Reset procedure has been known to delete your Favorites, so back them up
beforehand.
From the Nuvi drive, copy
'/Garmin/GPX/current.gpx' to a backup location on your computer.
After the hard reset, copy your backed up
'current.gpx' from your computer back to the '/Garmin/GPX/'
folder on the Nuvi, but be sure to rename it 'temp.gpx'.
On the next power cycle, the Favorites will be
read from 'temp.gpx' into the non-user accessible memory area on the
Nuvi where they are actually stored.
Perform the
Hard Reset:
*Note that this will clear all user
selected settings on the unit
Power the unit off.
Press and hold (and continue to hold) the
bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you
want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets
all your location settings and user preferences.
Then make sure the unit is fully charged,then go to the Garmin site and
register your product. Then download Garmin Updater and connect your
unit with a usb cable directly to your computer and not thru a USB hub.
Let the update go directly to the GPS and not a folder. It will take a
few hours even with a fast internet connection. I have attached a link
to the Garmin site. Thanks for using FixYa
This is weard sounding, I know, but it worked on my "non working" unit.....
On another forum it sayed to "hold your left thumb on the top left part of the screen, while you power the unit up from a USB power cable from a computer" and continues.... 'you must continue to hold your thumb on the screen until the linked icon shows up on the screen" After that let the unit charge for a while.
I did not try powering up whith my thumb on the top left part of the screen while in the car but hey... give it a try...
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
Market Name: On the Road
Serial Number (listed on the bottom of the device)
Question Type: Repair Information
Provide a short description of your problem or question: nuvi frozen on Garmin Logo
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
