Question about Microsoft Internet Explorer 7
When i am opening the internet explorer there is appearing a name insted of microsoft internet explorer Eg.- about :blank- deepak bhatt
    Problem Solver:
  • 14 Answers
This could be a virus! Did you try to change the homepage?
If this is a virus, even if they change the main page will re-appear.
Then run Spybot, CCleaner, Ad-aware and Anti-Virus.
Posted on Dec 22, 2008
Blank page
there is probably something that has hijacked your browsers search provider.
Changing the Default Search Engine in Internet Explorer
1. Click the Tools icon in the top-right corner of Internet Explorer.
2. Select Manage add-ons.
3. Choose Search Providers in the left pane of the box that appears.
In the Manage Add-ons menu in Internet Explorer, select the Search Providers add-on type.
4. Click the name of the search provider you'd like to make the default, and then click the Set as default button in the bottom right.
Within the Manage Add-ons window, you can also remove and reorganize your search providers. To add search providers, take these steps:
1. Click the Find more search providers... link at the bottom left to open the Internet Explorer Add-ons Gallery.
2. Click the Search link on this page, and type the name of the search engine you wish to add.
3. Click the result you want, and follow the instructions to add it.
Apr 12, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
Sometimes when I click on the Internet Explorer icon, and error message appears in front of a blank web page. The error message says "Internet Explorer has stopped working. Click to close program". When...
Try a scan with your virus scan, then with a malware scanner, i use Malwarebytes.
I would then use CCleaner, use the registry cleaner also.
This will clean out all your temp files, and remove any registry errors that may be causing IE from starting properly.
You could also use Firefox, or chrome as your browser if this does not fix it
Sep 05, 2010 | Microsoft Internet Explorer 8
INTERNET EXPLORER WON'T LET ME CONNECT TO MSN
Ok if you are able to connect Msn messanger it means you are connected to internet. In that case the first thing that you can do is you can do is :
1. Open an internet explorer
2. click on tools on the top
3. Click on options
4. CLick on Programs and then click on Reset web settings and then go to Advanced tab on the top and click on restore.
Thanks
Deepak
Oct 28, 2009 | Microsoft Windows XP Home Edition
Can't log in
To log-in into your Router by using its firmware.
At Internet Explorer in search engine: http://192.168.x.x (Gateway Address)
Login: admin / Password: admin
Hope this might give you some tips & ideas.
If i am helpful please rate me.
Thank you.
Beboy
Aug 18, 2009 | Computers & Internet
Blank page when opening a new tab in IE 8. I reset advanced options, didn't work. Do I need to check a box in there
Access the Internet Options dialog box. If the menu bar is visible, you can select "Tools" - "Internet Options".
If the Command Bar is visible, click the "Tools" button and select "Internet Options". If neither are available, try typing Alt + T then O.
When the "Internet Options" dialog box appears, underneath "Tabs", click the "Settings" button.
The "Tabbed Browsing Settings" dialog box appears. Underneath "When a new tab is opened, open" click the pull-down and choose from any one of the following options:
  • * A blank page
  • * The new tab page
  • * Your first home page
Click "OK" on the dialog boxes to store your settings.
Jul 06, 2009 | Microsoft Internet Explorer 8
I am observing on the left top of IE screen band
Start Internet Explorer. On your keyboard: * press and release the ALT key * press and release the T key * press and release the O key Click "use blank". Click "OK". Close Internet Explorer. Start Internet Explorer. You should now get a "blank" page.
Apr 26, 2009 | Microsoft Internet Explorer 6
I cannot remove the "about:blank" page from my computer.
If the page is about:blank that means you probabaly have no internet home page set. Go to Tools->Internet Options and set a home page, eg: google.com.
If you have to use task manager to close the browser then your computer is locking up. I reccommend you use a different browser or one of a higher version. firefox and internet explorer will do the job, as well as opera and safari.
Take care!
Jan 14, 2009 | Intel Easy PC Camera Webcam
Explorer problem
Hi
I suggest to restore the settings of your internet explorer to defaults. There could be bugs during your windows update.
1. Open internet explorer, go to tool --> Internet Options ---> Advanced tab ---> Reset.
Reset all the settings then restart your computer. In case you cannot open internet explorer because it will just give you a white blank page. try the following steps below.
1.1a Click Start -- type msconfig on start search box (for vista only). Click Run (for xp only). a pop up box window will show up (System utility configuration). Look for the tab Services.
Under services tab, put a check on the box that says "Hide all microsoft services" at the very bottom screen. Click apply then close. Restart the computer.
After restarting the computer follow step 1.
Keep me posted
Regards
Oct 18, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Internet Explorer 7 Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
