Question about Canon imageRUNNER C3200 Copier
Where is the fuser located in imageRunner 3200n drum
And how can i go to service mode on imageRunner 3200n
  • 92 Answers
But why do you want to go to service mode.
1º key of adicional functions
2º keys 2 and 8 than again adicional function.
Posted on Dec 22, 2008
I use canon imagerunner 330. what happen when it says switch main power off and on. E010 do i have electrical problem or technical problem
The Error code E010 means that there is a drag on the main motor. I would look in the fuser unit & see if the lower fuser roller is damaged or that the cleaning web is wraped around the upper fuser roller. Also try to turn the fuser. You may have a siezed ball bearing. Also, try to remove the drum unit and close the door and see if the code is gone, if so you have a problem with the drum unit, but I would say it is in the fuser unit...... Good Luck
Sep 05, 2010 | Canon imageRUNNER 400S Copier
Have a Canon Imagerunner 2022 has code E007 think its the fuser,if thats right how can you reset the machine
Yes, this is a fuser error.
Could be a temperature problem, a faulty sensor, DC Controller, or a rotational / mechanical error.
You should only clear the error if you are sure the cause of the error has been fixed. It is cleared in Service Mode.
You should get a Service Technician to check / fix this.
Dec 09, 2009 | Canon imageRUNNER 2022 Grayscale Copier
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
Canon imageRunner 3200n printing problem in color
ok you are in the right area are you taking the belt off to clean those rollers???? if not do that 1st. then you may have to clear the dc controller but 1st do a DPRINT under the service function menu. after the dccon clear you will need to put those #s back in
Dec 24, 2008 | Canon imageRUNNER C3200 Copier
Error 000001-0004 ON MY IMAGE RUNNER 2620N,000001-0003 on3200n
ok that code has nothing to do with your drums that code is for a error in the fuser unit, you have to reset it in this order ADD FUNC key// then hold down the 2 & 8 keys at the same time / then ADD FUNC key again... screen should change to serv mode.... then in this order.touch copier/func/clear/err. ok turn off copier then back on... if code comes back you have a bad fuser unit swap it out clear the code again then try the new unit
Dec 22, 2008 | Canon Office Equipment & Supplies
How to get in service mode on Canon ImageRunner 1630
You DO NOT WANT TO RESET THIS ERROR CODE !!!!!!!
there is a problem with the fuser, if you reset it most likely it will melt the rollers in the machine.
check the lamp (burn out), and thermofuse. replace
Oct 15, 2008 | Canon imageRUNNER 1630 Copier
Canon imagerunner 2010f wont print
You may need to go into service mode and reset the drum status. Service mode is dangerous and recommended for Canon techs only.
Aug 25, 2008 | Canon imageRUNNER 2010F All-In-One Printer
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Canon Imagerunner 5000 error E000001-0000
Sort of, since both are fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
May 18, 2008 | Canon imageRUNNER 5000 Copier
Black streak on one side
Stop the print with a little practice, half to 3/4 of the way threw machine by opening door at right time. You want the paper to be jammed/stopped after the drum (has image on paper) but before fuser (print should still rub off)
fuser is blue green 300 thingy
If print is line less where stopped then mark is from fuser, replace
If print has line before fuser then it is drum/cartridge
..probally drum..need more info to know for sure, ie you say mark when faxing I guessing you mean receiving, what happens in copy mode is same as printing I'm assuming too
Nov 08, 2007 | Canon imageRUNNER 1370F All-In-One Laser...
Canon imageRUNNER C3200 Copier Logo
71 people viewed this question
old marine
old marine
