Question about HP vs15 15"LCD Flat Panel Monitor
Monitor goes to sleep mode quickly without video cable
Im using a plasma tv as my pc monitor. i have not been able to figure out why i cannot get any sound from the plasma but i have discovered that you can get sound from the original cpu monitor while using the plasma at the same time. so the plasma shows the picture while the monitor makes the sounds-they work as a team. but now my monitor goes to sleep mode after about a minute... how do i make it not go into sleep mode so quickly?
  • 1 more comment
  • garcia04 Dec 22, 2008
    i was able to follow the start, control panel, and power options directions. but when i right click desktop there is no properties button. but there is a personalize option....
    okay sorry i did find the screen saver and turned it off through personalize. so i did turn it off and change everything to never but when i played a song, at about minute 1 the music stopped and the blue light on the monitor changed to yellow.
    i have a desktop.
    when i click on power option the screen i see is "select a power plan" and on the left side there are menus. so i said to Turn off display: NEVER and put the computer to sleep NEVER. but after about a minute the sound cuts off and its asleep again...
  • 15,935 Answers
Right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Posted on Dec 22, 2008
  • blueextc3221
    blueextc3221 Dec 22, 2008
    start - control panel - power options. Change top pulldown menu to Home/Office Desktop and the other 3 below (all pull down menus)to "never"
    Then "OK"
    Additionally, you may have a tab that says Hibernate. Unclick the box that says Enable Hybernation.
    Is this a laptop or desktop?
  • blueextc3221
    For sound, you will need a cable from the output of your soundcard to the input of the monitor if it is equipped with internal speakers.
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
I recently purchased a used Dell Monitor e193fpc. I see the background picture it says auto picture adjusting and goes black into sleep mode. Without a hookup to computer is shows a self test, and goes...
Have you tried lowering the resolution of your computer? Better yet you can try booting up the pc in safe mode. If that work, then probably the problem is that the monitor does not support high resolution.
You can also check if your video cables are properly inserted to the correct slots. Also check if your video cables are damaged. Thank you.
Sep 16, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Im using my tv as a monitor, when i turn on my music and then leave the computer to do chores, the computer goes to no signal and i cant listen to my music, how do i keep it from doing this?
Sounds like either your computer is in hibernation mode or your TV is set to sleep, what type of connection to your computer are you using? I do believe in this model Vizio there is a sleep option on each of the Video sources. But I would guess its your computer going into either sleep mode or in your running windows 7 Hybrid sleep mode.
Jul 02, 2011 | Vizio L32 32 in. LCD HDTV
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Plasma vizio 50 inch goes into deep sleep mode
when turned on tv no signal comes on a few minutes later deep sleep mode and tv turns on
Sep 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs15 15"LCD Flat Panel Monitor Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
