Question about Toshiba Tecra S2 Notebook
Forget cmos password on a tecra s2
Bios password prompt waiting for the right entry
    Sergeant:
  • 367 Answers
Remove both batteries the usable battery and the CMOS battery for about 15 minutes and then reinstall you should be good to go.
Posted on Jan 19, 2009
Removal of supervisor passwprd
Remove CMOS battery inside of the motherboard and "short" contacts. wait about 5 minutes and replace battery. It should reset bios to factory status. Won't affect your operating system and hard drive.
Apr 25, 2015 | Toshiba Tecra R850 Series Black Notebook...
Tecra 8200 password
use bios password code for reset bios password
Removing BIOS password on Toshiba Satellite Laptop - YouTube
The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must remove the battery from
Jun 18, 2014 | Toshiba Tecra 8200 PT820U-OFG8C801...
I have a tosiba tecra 9100 laptop that when I boot up it ask for a bios password, i bought from a garage sale and noone seems to know the password is there neway i can clear that password and start over...
There is a battery on the motherboard. Removing it for about 1/2 hour should clear the bios. There are several software methods also. Google 'bios password removal' to find one.
Jul 18, 2009 | Toshiba Tecra 9100 Notebook
Password for bios
If u have forget the bios password...u won't b able to enter bios....Bios password is stored in cmos battery...its volatile memory..if u can remove the cmos battery and then insert it again....Bios will not ask for password.....This is a small siver color battery on the motherboard..
Apr 21, 2009 | Toshiba Tecra 9000 Notebook
I forget my password bios for toshiba pta83e
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Mar 28, 2009 | Toshiba Tecra S2 Notebook
Toshiba tecra m4 bios password
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it by pressing F12 and use BIOS / CMOS Tools from it.
Feb 01, 2009 | Toshiba Tecra M4 Notebook
Bios password lose
Desktop
Power off the computer and make sure that it is unplugged.
Open up your computer case. You need physical access to the motherboard to complete this procedure.
Find a circular, (mostly) silver metallic object on the motherboard. This is the CMOS battery.
CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. (See Warnings)
Set the battery back into place and power on the computer.
The computer should then warn you that the CMOS configuration could not be found. You can either reconfigure it yourself or restore defaults. Restoring the default configuration should be fine.
You will notice that the BIOS password has been cleared and you can boot without it. You may reset the BIOS password to something else by going into the BIOS configuration and setting a new User Password (The Supervisor Password controls access to the BIOS, NOT the computer!)
Laptop
Remember that laptops can be trickier, especially if it's a newer model. If it has a security chip on the motherboard forget about it. You either have to physically remove the chip or contact the mfg for the "master" password. If you can boot up off of a cd or floppy try any of these methods:Create a Win98SE bootable media "or anything that lets you boot into MS-DOS" and boot off of it.
When the A:\> prompt appears type debug and press enter.
You will then only see a "-".
Type o 70 2E "include the spaces" and press Enter.
Type o 71 ff "include the spaces" and press Enter.
Type q and press Enter.
Here are a list of common mfg backdoor passwords:
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet, %øåñòü ïpîáåëîâ%, %äåâÿòü ïpîáåëîâ%
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
Other passwords you may try (for AMI/AWARD or other BIOSes) - LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME, Syxz, Wodj gvs
source:http://www.wikihow.com/Break-a-BIOS-Password
please rate!
Jan 21, 2009 | Toshiba Tecra S1 Notebook
usually that is set by the company that makes the laptop... unhooking the cmos battery for a period of time often removes it.
Robert
Dec 22, 2008 | Toshiba Tecra S2 Notebook
How to reset bios password
underneath the button cover (plastic cover over power button etc) there is sw1 4 switches ,
put them all to on the power laptop then off again put switches back to what they were then on again
and presto bios password is no more
Jan 30, 2008 | Acer TravelMate 2300 Notebook
Open Questions:
Toshiba Laptop will not start up properly' Cont Us +1888784-9316 If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 19, 2018 | Toshiba Computers & Internet
See all Toshiba Tecra S2 Notebook Questions
Toshiba Tecra S2 Notebook Logo
297 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
