Question about Mitsubishi VS-60805 60" Rear Projection Television
Green color/tint over the display
Im having problems with my 4 y.o. Mitsubishi VS-60805. The whole picture comes out green. Reds are still noticable but everything else in the picture is green. Does anyone know how to fix this? Thanks!
Dont listen to getting a tech, take the front speaker covers off, and then the panel with a screw driver and you'll see a device that has six knobs, the top middle one is the green, and all adjust something differnt. the top panel are color and the bottom row is clarity, just play and it will be fixed
Posted on Sep 04, 2007
    Genius:
  • 1,074 Answers
Yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Posted on Apr 08, 2007
Green tint on picture 60in mitsubishi
Turn the color all the way off---examine the screen to see if black and white or screen green in areas or whole screen.
The other possible issue is tint will not vary enough from green to purple when adjusted.
Two different issues--which do you seem to have?
May 31, 2012 | Mitsubishi WD-60737 60 in. HDTV
Picture has lots of green
i think that your TV picture tube has a problem..tnx
Sep 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Mitsubishi cs-40503 tint problem
internal codes are good, but when the is like what you post then a tech is what you need.it seems that one of the problem is the flyback transformer or the CRT cap.have a tech check you unit.
Sep 08, 2008 | Mitsubishi CS-40503 TV
Picture turns red and blue color after television has warmed up
sounds like u are losing green? is that right. could be loose connections somewhere because it works at start up then fails when it heats up. Look in the yellow pages for a mitz auth servicer or call mitsubishi for one near u.
Dec 13, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Picture has greenish tint that I can't adjust out
There is a crt drive problem and you can isolate it by unpluggin g the set, removing the green crt socket, in the middle of the three tubes is the green tube by the way, remove one of the other tubes and switching the crt sockets and turn it on. If the set is still greenish, then the green crt is bad and needs replacement, if another color is primart, then it is going to be the green crt drive circuit and is going to need to be serviced. Good Luck
Oct 07, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
