Question about Alpine Car Audio & Video
Display read "disc error" then "no magazine"
While playing, disc stopped, error msg appeared- then display read "no magazine". cannot extract magazine or change discs as head unit does not recognize magazine in place. this unit is a changer in a land rover and has the alpine product # xqe100240
has been working w/o problem until now.
    Top Expert:
  • Alpine Master
  • 49,781 Answers
Most likely there is a CD jammed in transit between the player mechanism and the magazine. This is a common problem. You will have to remove the unit and disassemble it sufficiently to get the CD back in the magazine and, in turn, allow the magazine to be removed.
Posted on Jan 28, 2018
Eagleeyes
  • 199 Answers
SOURCE: Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Posted on Feb 24, 2008
easyq
  • 144 Answers
SOURCE: manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Posted on Aug 08, 2008
SOURCE: Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
Posted on Sep 18, 2008
landsend
  • 1066 Answers
SOURCE: which radio for land rover
Usually an Alpine unit.  Try ebay.
Posted on Apr 03, 2009
SOURCE: cant remove magazin with cds without changer is on power
Is there a pin-hole on the front of the cassette? If so, insert a paper clip into the hole to manually release the cassette.
Posted on Sep 08, 2009
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
The song is playing and running suddenly the song stops and the error msg when i restart my dvd. The error msg is F61 displays in Dvd's display. Please give a rply.
Hi ahamedfaisal,
Does F61 appear after a minute of playing or shuts down immediately after you power on the unit?
Jdvillanueva
Mar 16, 2011 | Panasonic Audio Players & Recorders
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
I can not get the Magazine to release. I see where it say's Manual Magazine realease, but can't tell what to do. Please help Darrell Mack
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Reduce the output level from any external components connected to the music center. Make sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1 jack and the multi-pin connector on the other end is firmly seated in the Accustoms module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers to the Accustoms module. To restore communication between the music center and the speakers turn the music center off for ten seconds, then on again. Check the connections for any external components. Make sure to select the correct source for the desired input. Be sure the CD is placed correctly, label-side up, in the magazine, and the magazine is inserted properly in the music center. Increase the volume. Check to see if MUTE is lit on the display. If it is, press the MUTE button on the remote control to un-mute the sound. Disconnect any headphones. Connect the FM and AM antennae. Check to see if the play symbol in the display is lit. After pressing the CD key, wait a few seconds before pressing PLAY. Make sure the magazine is properly inserted. Check to see if there is a disc in the magazine, label-side up. Display shows a flashing box for a disc that is label-side down or cannot be read. There may be dirt or dust on the CD. If so, clean the CD. Eject the magazine and try loading the CD again. A display message “E01” indicates a mechanical error. Unplug the music center. Reconnect power and try again. If “E01” reappears, call customer service.
If the CD stuck again as you stated in your earlier comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside down so that the "Manual Magazine Release" is in your upper right hand. Locate the two small rectangular "Open Slots" on the side. You need to use the top slot. Use the screwdriver and push the little "U" or "Y" Shaped metal upward which is just below the manual release. The magazine will come out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Bose Lifestyle 20 System
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Unable to open e-mail attachment
Open Files with .MSG File Extension Do you want to open a message with the Outlook .MSG file extension? The Encryptomatic MSG File Viewer makes it easy access Outlook MAPI message files (.msg files) created in Outlook 2000/XP/2003.
MSG Viewer reads .msg files encoded in western characters. It will display the text contents of the .msg file on your monitor. You can also print the message, save it to a text file, and extract file attachments.
Easy to Use Encryptomatic's Outlook .MSG Viewer is simple to use. It may be optionally installed as the default .msg file handler. This enables you to display a .msg file by simply double clicking it.
Extracts File Attachments from Outlook .MSG Message Files
Users can extract and save to disk any file attachments that were included in the Outlook .msg file, a useful feature not found in other viewers of this price class. To extract email attachments, just double click on the file attachment and save it to a directory.
viewer-screen.jpg What it Doesn't Do
The MSG Viewer is designed to give you quick access to an .msg file's text contents, file attachments and header information. It does not render colors, formatting or graphics, and it is not a full featured substitute for Outlook. With an RTF message with colored text and font formatting, the text will appear in black and white and the paragraph formatting will be lost (as in the message above). MSG Viewer displays only Western characters.
Feb 26, 2008 | HP Pavilion dv6000z Notebook
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Car Audio & Video Logo
193 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
