Question about Whirlpool LGQ8611L Gas Dryer
Burner comes on, but doesn't stay lit
I have replaced the coils, but the burner won't light. The ignitor does light, but won't ignite the gas. Could the new coils be bad? or what do you suggest? Thank you!
  • chrisnmiss83 Dec 22, 2008
    Radiant heat sensor was replaced with a new one already. Blew out window also. Still not working.
  • 113 Answers
Most likely to be the falme sensor. Its attatched to the flame tunnel. Has a little window on it. First just try cleaning the window. The sensor sends signal to the coils to open and allow gas to the burner. Mat have to replace the sensor. Easy and inexpensive. Dave www.washermd.com
Posted on Dec 22, 2008
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Broiler burns but the bottom burner on the stove will not come on the glow igniter turns orange but the burner doesn't light also one eye doesn't light, the striker sparks but the burner...
FOR THE OVEN NOT HEATING
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
FOR THE SURFACE BURNER NOT LIGHTING The holes on the burner espically those around where the electrode are dirty/clogged. By using a paper clip/safety pin to push in and clear the holes then clean the burner up with some steel wool the burner should light. GENE
Aug 29, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Burners won`t stay lit.........
There are several possible causes for this. Bad flame sensor, bad thermostat switch, blocked air vent, or bad gas coils.
This website
http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
Has very good troubleshooting and repair information for all of the possibilities
Feb 02, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Igniter in oven will try to ignite. Hear gas flow. Can see spark on upper burner assembly but it does not ignite. Use custom broil and it will ignite the upper burner but will not stay lit after ignition...
the ignitor may be faulty and not pulling enough power to keep the as valve open in order to light them oven, even though it is getting red or glowing the power is not enough.try and replace the ignitor
Jan 24, 2010 | Whirlpool GS460 Gas Kitchen Range
Gas will not stay lit on my Kenmore series 80 dryer..
If the ignitor is working properly (glowing visibly) and the burner will not light, then I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit gas flow to the burner. If faulty the gas valves will not open and the burner cannot light. It is recommended that if any are suspected of being faulty, that both (all) be changed at the same time and they will likely come from the parts supplier as a set. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Kenmore 800 7983 Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
Maytag Neptune MDG5500AWW Not Heating
The coils are the #1 failure in gas dryers, below is a description of how they work. This excerpt from; www.repairclinic.com.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Jul 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Model LG5801XK Gas clothes dryer
first ck gas to unit, next is ck the coils on the burner valve right, there(i just looked up and this is an older unit) set of coils is about $85, the entire burner valve including coils and new ignitor is about $135.that would be my bet the whole thing but is it worth it putting 135 into the dryer
Feb 26, 2008 | Dryers
Hotpoint RGB745 Burner Problems- Unique, needs help
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
Apr 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Whirlpool LGQ8611L Gas Dryer Logo
218 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
