Question about Kenwood VR-6050 Receiver
Display Lights The display on my receiver keeps going out. The display turns on sometimes, but not all the time. I tried resetting the unit. Does it have something to do with the dimmer?
  • dustin carter Apr 19, 2007
    Bump! Does anyone have any ideas?
Send it in to kenwood wirth it the damn thing got power tords it lol i got it pushing 200 wattsx5 with a power esp
Posted on Jun 25, 2007
SOURCE:
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
Receiving error code FL on washer display.
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Dec 07, 2012 | Crosley CW6000 Front Load Washer
NAD T763 - i turned it on and all the lights on the display lit up and stay on. It doesn't work at all !! Any suggestions?
Have you tried doing a factory reset?
1. With unit powered ON, press the VIDEO and TONE DEFEAT buttons.
2. Display will show "AH RESET DONE".
3. Power off (from rear panel switch) and back on.
Jan 29, 2011 | NAD T763 Receiver
I just turn off my Sony Walkman ,and then the screen display :Power Off.but its not completely off ,the words: Power Off still display on the screen
Remove off the battery for sometime and keep off for sometime.
Later reset the batery and test, if the fault recurrs then it is possible that the mP is not resettting. try and see for any errors in the board, remove and clean.
Sep 23, 2010 | Audio Players & Recorders
MOTU 828MK3 led's flash then no lights do they have a switching power supply ?? Any one have a diagram of the unit
I have a MOTU 828 MK3 and have had trouble with the display lights not working on one of my units. I tried the unplugging and switching from 120 to 220 and back. Sometimes when I started it up it would come on and quickly go off or not even come on at all. I was using the unit by reading the numbers using a flashlight. One day I noticed the light undulating as if trying to come on and I just rubbed my finger over the light as if to try and coax it to come on. The next time I turned the unit on the light came on and stayed lit for the entire session. The light has only gone out one time since, after many sessions. The time it went out, I just rubbed the top of a finger over the display and it came on the next time the unit was started. I now make a habit of rubbing it every time I turn it on. It has not failed since. Sounds funny as it might just be my karma, but I think it more likely that it works because of a slight static charge that I create with the light rubbing of my finger. Just thought you might like to know. Doc Mason
Nov 06, 2009 | Audio Players & Recorders
Etrex vista will not display any map
I had the same problem for months. i don't know what part of this worked or if it was a fluke that it finally worked. I downloaded the newer firmware for the garmin and installed it ( http://www8.garmin.com/products/webupdater/ ) then tried adding maps, that didn't work, then tried 3-4 times resetting the garmin, and each time tried adding maps and it didn't work - turns out I wasn't really resetting it (I think) it appeared that the successful reset was holding down the clicker key and the pages key while starting up, and keeping them held down for a long time (15 seconds?) - there was no sign that it was resetting except a faint illumination, then when I let go of those 2 keys it went through the setup sequence. the only way I knew it had finally reset was when the page came my pointer was in the middle of the united states. I had repeatedly tried resetting before and the pointer/map page came up to where I was last at, so it hadn't really been resetting. I'm very displeased that it took 5-10 tries to get this to work and this happened on 2 units.
I reloaded the maps after it had properly reset and they actually display and are on the map list!
this is the second etrex unit ive had this problem with, and the first one was just as flaky - taking many reset events (see master and super master reset on other etrex threads at this site)
Mar 15, 2009 | Garmin eTrex Vista GPS Receiver
Firmware upgrade failure
Try this for the reset
First turn the unit off then
hold down the "Pure Direct" and the "Direct" buttons on the display at the same time. And while you are still holding them down turn the unit on with the power button on the display.
this should reset the microprocessor.
You will need to put all custom settings back in.
Let me know if this helps.
Dave
Jun 06, 2008 | Denon AVR-3805 Receiver
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Kenwood VR-6050 Receiver Logo
188 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
