Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Faint red bar
My panasonic cinemavision 1080i rear projection hdtv has a faint red bar horizontally across the bottom. What is causing this. Can it be fixed.
Before I notice the problem, a bar stool fell into the side of the unit....not a major crash, but could this have knocked a bulb loose?
  • Panasonic Master
  • 727 Answers
This model does not have a bulb. It uses older CRTs.(cathode ray tubes). Your convergence probably is off now. You may be able to re-align it, but between you and me, its an old TV and not worth putting money into. If you can adjust it back, great, it now, Id live with it until you can replace it. check your menu for convergence settings.
Posted on Feb 02, 2018
5 Suggested Answers
SOURCE: My panasonic cinemavision hdtv 1080i will not give
i have the same problem, did you ever get a solution?
Posted on Jun 24, 2010
welcomejee
  • 10594 Answers
SOURCE: We have a PT-47WX51CE panasonic cinemavision hdtv
All that mess in picture is due to failure of convergence output chips in this tv.
Replace convergence output ICs (two ICs) to solve picture problem. Required ICs are available in Part Store, click the link to have price info.
Thanks.
Posted on Jun 25, 2010
  • 8457 Answers
SOURCE: I have a Panasonic HDTV
The tv have a problems known as a convergence problems,it dead.The tv convergence board,require replacing 2 STK convergence ICS and some or all it resistors.Yes.U have a soldering iron,desoldering pump or desoldering braids,solders and u can do basic soldering?Yes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop,will cost u like $300-350 for parts and labors.
Posted on Oct 27, 2010
  • 101 Answers
SOURCE: panasonic cinemavision hdtv 1080i projection TV.
go to this link for the manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=d17d8491251fb501911086409da7f697&modelid=275504&q=Panasonic+PT-47WX49
Posted on Dec 18, 2010
My 51" Panasonic CinemaVision rear-projection HDTV
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
We have a PT-47WX51CE panasonic cinemavision hdtv 1080i and the colour is off. We see separated mainly green and magenta and the picture is warped with some lines.
Thanks.
Jun 25, 2010 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic cinemavision hdtv 1080i projection TV. Is this tv digital? how does one access the digital aspect?
Jun 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Helpme
Replace Both of your convergence ICs they are big black ics STK392-110? use 180s .
Dec 14, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
