Question about Microsoft Zune JS8-00001 Digital Media Player
Please help!!!!!!!!!!!!!!!!!!!!!!1 how do i unblock mp 3
  • Blazer III May 11, 2010
    if you can i can help
    can you explain it better?
  • 8,596 Answers
My Zune 30 is frozen. What should I do?
Follow these steps:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required—you can go back to using your Zune!
Posted on Jan 01, 2009
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | Brother MFC Office Equipment & Supplies
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
I downloaded Canon Mp Navigator but drivers not supported?
1. Go into device manager and find the scanner
2. Right click and choose update driver.
3. Select the driver manually from list and update.
Hopefully this helps.
Sep 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I want to unblock websites on my playstation3
  1. tep 1 Determine which blocked websites you would like to gain access to.
  2. Step 2 Choose a website that features an "Unblock" tool to help you.
  3. Step 3 Enter the URL in the appropriate section on the website. Usually there will be a button to click that says "Unblock Me"--click it.
  4. Step 4 Attempt to gain entry onto the blocked website. If for some reason it didn't work, you may want to try another unblocking website.
  5. Step 5 Clear the Internet history.
i hope this helps
Mar 20, 2009 | Sony Playstation 3 (PS3) Console
Error SC541 ON NRG MP 1600L
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Good luck and please rate me, thanks.
Feb 26, 2009 | Gestetner DSm615 Digital Imaging System
How to enter the maintance mode on a Ricoh MP 3350
If you want to enter in Service program mode please,
press Clear (yellow) button, 1 0 7, and press and hold Stop (orange) button for 3 seconds.
Jan 17, 2009 | Office Equipment & Supplies
Codes printer canon mp 160
Go to
#1 Select Multifunction
#2 Select Inkjet
#3 Select Pixima MP 160
Scroll down to Please enter your question bar
Click mouse inside the bar area
Type in code
Click on search
Jul 30, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How to unlocked nokia N73?
Your code's for the Vodafone network are:
You should try 7 first then 1, 2, 3...
You only get 5 goes, after that your phone needs to go to the phone clinic.
If you're on a different network let me know and I will give you the codes. I need the IMEI (I've got it) the country and network.
Jan 18, 2008 | Nokia N73 Cellular Phone
Microsoft Zune JS8-00001 Digital Media Player Logo
64 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
