Question about SanDisk Sansa e250 MP3 Player
My sansa250 will not shut off
There is no reset button, just short of unscrewing the back, how am i supposed to turn it off
Jennifer
  • mkahassai Dec 23, 2008
    my mp3 player wont turn off
    Problem Solver:
  • 10 Answers
The reset buton is the same as the 'On/Off' button. Just hold it down for 15 seconds.
~loli~
Posted on Dec 23, 2008
Canon x700 shut off
I will tell you what worked for me and i am not responsible for anything that goes wrong whatsoever.
I unscrewed the projector bolts for the lamp, took it out safely, then unscrewed all the bolts for the projector casing, be careful not to break anything. And use precaution. Then you will see the projector inside and the entire motherboard hard drive. On the top near a corner you will see two larger black wires connecting to some sort of device, in the center of that little device is a little black button, I clicked it, put it all back together and the projector started. Hopefully it works for you.
Apr 16, 2012 | Canon REALiS X700 LCD Projector
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Have a GF500 Monitor Propane Heater - keeps shutting down. Once it reaches the set termperature the burner begins to back off, and then the "burner status" buttons start flashing and the unit...
This sounds like your thermo-couple has a short, or is defective, it is supposed to kick off at the set temperature, then turn the burner back on after it cools down, a temperature probe is usually coonected o this as well, either one of which could be defective. Try to replace those parts and see if that does the trick.
Jan 17, 2011 | Heating & Cooling
Playing a game system just shuts down and now the power indicator is blinking and wont turn back on and when it does it cuts out again?
hello have you tried resetting it take power lead out of the back then reinsert it back in while doing this press and hold standby button on the front of the ps3 you will hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset fingers crossed
regards
shaun
Dec 03, 2010 | Sony PlayStation® 3 (60 GB) Console
My garmin 305 (for running) will not shut off..soft reset just turns it back on ..the other buttons are frozen
Try hard reset, if not working, your device probably needs to go to support
Hard reset : device must be off (short press on mode plus lap/reset)
then hold mode and start buttons for 10 seconds, then pulse on lap/reset button
You'll loose all data, and go back to factory settings.
Before trying such solution you may try reinstalling last software from PC and USB cable
Aug 25, 2010 | Garmin Edge 305 GPS Receiver
My nintendo wii turns off when you press the on/off button on the unit or on the remote .
Yes, it's supposed to. If you quickly press the power button on the remote, it will only shut off the controller, but if you hold it down for even a short amount of time, it will shut off the whole system.
Jul 20, 2010 | Nintendo Wii Console
I just replaced the inner an outer tierod ends.the steering wont turn back after u make a turn
You need a frontend alignment. If you took off the entire tierod you may have hung the rod backwards and it is catching. When you unscrew the ends you are suppose to count the twists and then replace the ends with the same amount of twists.
If the rod is too long or too short now it will put the tires in a position that is not aligned. You can align this temporarily by straightening the wheel so the tires are parallel. Then measure the inside of the rim so that the BACK of the rims are about 3/8 of a inch wider than the BACK of the rims in the front of the tire. The tires are suppose to travel knob kneed about 3/8" toe-in.
Apr 15, 2010 | 1999 Ford Taurus
The blue light will not shut off and the device will no longer connect to my cell phone. Motorola h560 hands free device
Hey Jennifer - might I recommend resetting the device completely and going through the pairing process again?
To do this, first turn the switch to "off" by sliding it back, toward the earpiece/speaker. Then press both volume buttons and the "call" button at the same time, holding it for about 10 seconds. That will reset it to "like new", and then you can re-pair the phone and device. If you need holp, you can check out the manual and instructions here:
http://www.motorola.com/support/v/index.jsp?vgnextoid=aee54c26f3f8f110VgnVCM1000008406b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
Mar 09, 2010 | Motorola Mobility H560 Bluetooth Headset
SanDisk Sansa e250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
