Question about X2Gen MG19MY 19" LCD Monitor
Something is blown inside my monitor
Every time i turn on the computer, the monitor blinks on and stays off. I see a half of second of the of the image before it clicks off. This all happen in transport to new location.
  • dkenbutler Dec 23, 2008
    Well, I know that it is the monitor because the computer works on every other monitor I connect it to. Realitly tell me to purchase another monitor but I rally don't mant to. So I guess what I really need is some information to help me trooble-shoot my own monitor. Looking for a service manual or some sort.
  • 679 Answers
This is not a good sign, I have been there, other than a loose connector, it sounds like the module that enables the power up cycle is blown. Have you tried the monitor on another machine? if the same thing is happening then it's time for service. There are several other things it could be but there is no sense running down a list of possibles till we know that it is 100% the monitor and not the machine. If it is the monitor you had better find out if it's covered, or not, the price has come down so mutch that if it's not covered, the shipping on a 19 inch that I also needed packeing at the local Pak and ship ,was over 70.00 just to send it to viewsonic, luckilly they lost it and paid me the original price after a 6 week wait, make sure you take insurance if it must go. I'll wait for you to figure out if it's the monitor.thanks Gym
Posted on Dec 22, 2008
Samsung 943NW Monitor-----the led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or...
It can be due to dying power supply due to bad caps, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 06, 2010 | Samsung 943NW Monitor
Image blinks off after about 1 second after being powered up. Cut the power off at monitor, then turn back on and it repeats. Full image from computer shows up for about 1 second then disappears. The...
Please look here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Oct 13, 2010 | Westinghouse L1975NW Monitor
Hannspree computer monitor will not stay on.
More likely to be failed DC filter caps in the power supply section, that will be the first place to look, this is common problem with ALL LCD monitors, sad but ture. You may want to find out if it is still under warranty.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 24, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
The Monitor won't stay on
Try it on another PC first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board:
http://www.lcdrepair.us
Jun 13, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Montitor display turns off. Not power, green light stays on.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Similar board: http://www.lcdrepair.us/SE178WFPcinverter-power.html
May 14, 2010 | Dell SE198WFP LCD Monitor
Monitor will not turn on, just blink...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 17, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor needs a long warm up time before ready to use. computer turns it on but it blinks off. after about 10 to 15 minutes the monitor will stay on.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 04, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Monitor will not stay on
Same boat 1.5 years old and the screeen will shut down in about 1-3 seconds as long as i turn it on.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
63 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
