Question about Comfort LLC Arrow 5650dtc Staple Gun & Desktop Stapler With Comfort
Put back together a easy shot staple gun
I loaded the wrong staples and had to take the stapler apart, of coarse the spring came out as did the handle and now I can`t put it back together. any one have a schematic drawing or a picture of the insides
  • 1 more comment
  • Anonymous Jan 24, 2009
    cant put it back together
    cant put it back togther
  • Anonymous Feb 16, 2009
    i have the same problem
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
SOURCE: refilling the staple gun
I own a Power Sot and the directions are very clear. Squeeze the clip at the back of the unit and pull the spring-loaded clip out. Put your staples in and GO!!
Posted on Oct 13, 2008
  • 242 Answers
SOURCE: putting staples in thew easy shot
Squeeze the plastic clips that are located on the opposite side from where the staples come out. Squeeze and pull straight out. There is a rail inside, where the staples sit. When loading the staples, keep them in the same orientation as they are expected to come out when you are using it (sharp edge down).
Posted on Oct 27, 2008
  • 242 Answers
On this model, there should be a spring on the arm. Compress the spring and put the staples in. When you close it, the metal part on the end of the spring holds the staples tight.
I arm and spring below
___I staples here I_____))))))))))))))))))))))))))))))))))))))))))))))____[___]
Posted on Nov 10, 2008
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
How do I load staples into my JT21 staple gun?
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Feb 08, 2011 | Tools & Hardware - Others
Every time I load my easy shot 5650 stapler they fall out the end they are supposed to shoot out...why is that ??
The way you load this staple gun is: (1) turn it upside down (2) press the unlock tabs on the rear end of the loading slide trey and pull it back (3) droup a row of staples into the slot w with the pointed end facing up, while keeping the gun upside down, push the spring loaded slide tray forward until the locking tabe engauge. (4) turn the gun rightside up (away from you), and fire it. the stape should come out normally, the rest should not fall out.
Nov 28, 2010 | Comfort LLC Arrow 5650dtc Staple Gun &...
I loaded the stapler as described above. Now I hear the staples sliding around inside the casing. I loaded as many staples as the gun will hold. I pressed the handle down and three staples came out at...
You need to load just enough staples in it that when you put retaining spring and clip back in that it will let catch on back of spring to go into slot in frame. I hope this helps. Thank you
Nov 19, 2010 | Arrow T50P ARROW STAPLE GUN
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
See above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Feb 02, 2009 | Black & Decker 5700 Powershot Forward...
Refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Comfort LLC Arrow 5650dtc Staple Gun & Desktop Stapler With Comfort Logo
1,706 people viewed this question
Top Comfort LLC Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Comfort LLC Tool and Hardware - Other Expert? Answer questions, earn points and help others
