Question about Fisher and Paykel (IWL12)
My electricity went out for four days and now my washer wont work
    Problem Solver:
  • 19 Answers
Check Breaker first, 2nd Check to see if washer is on a gfi receptcle. press reset. If this does not work send me more info on Cir. You might want to test outlet and see if there is power there. Storms can tear up app' s Hope its a simple gfi prob .
Posted on Jan 04, 2009
Fix Power Window Drivers side
sounds like the electrical motor on that window went out
Apr 05, 2015 | 1996 Nissan Maxima
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
My washer wont drain
I was working on one of these machines one day with the same problem. I took the electric pump apart and found a shoestring in it.
I have a video which shows how to get into the machine and more HERE
Dec 27, 2010 | GE WBSR3140DW Top Load Washer
My dryer has stopped heating completely. Worked fine for six years and stopped heating four days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 06, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
Car transmission issues and now wont start
check your idle control valve/sensor and torque converter/solenoid these four things are common problems
Nov 04, 2009 | 2002 Dodge Stratus
Electrical problem with car 2006 Jetta 2.5
have you checked the fuses make sure they are not burned.its usually the red but check all of them.
Jul 12, 2009 | 2006 Volkswagen Jetta
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Electric windows quit working
My van just did the same thing, it finally went up, then wouldnt go back down, then a few days later it went down again and got stuck. It was pouring so i had to park it in the shop, the next morning I went out, and it wouldnt go up, so i got mad and smacked my door a few times and it went up, now it currently works, but im not rolling it down one more time. Everyone i've talked to says it may be the window relay. So im looking for some diagrams to find out where the window relay is, thats how i got to this site, Hope this helps any of you.
Jun 26, 2008 | 1996 Plymouth Voyager
Front loading washer door lock
It has not been resolved yet. It has been worked on twice now. It has a new electric panel (not sure what it is really called other than the brain) and part of the motor has been replaced. Now apparently the heater core is not working. The tech told me the heater core probably went out which caused the other 2 issues. I suggest buying the extended warranty if it is ever offered to you. My washer is only 9 month.
Aug 29, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
64 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
