Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
WATER FILTER SYMBOL IS ON. WHAT DOES THIS MEAN AND HOW DO I TURN
WE DON'T SEE ANY PROBLEMS BUT THE WATER FILTER SYMBOL WITH A DROP UNDERNEATH IS ON AND WE DON'T KNOW WHAT'S WRONG OR HOW TO TURN IT OFF. CAN YOU HELP?
  • 3 Answers
This is the indicator that suggests that it is time to change the water filter.
After 5 months of operation, the indicator shows as light pink. At this point, it is a reminder to aquire a replacement filter,
After 6 months of operation, the indicator turns to red. This is now the suggested time to change the indicator.
Even if you aren't using the water, the filter indicator still lights as this is simply a timer and does not measure water flow through the filter.
To reset the indicator, press and hold the Fridge and Power Cool buttons at the same time for 3 seconds. These 2 buttons are on the right side of the display panel. They are the first 2 buttons to the right of this indicator.
Printed on the panel, there is a line connecting the buttons with a miniature of the indicator in the middle. The instruction to hold the buttons for 3 seconds is printed below the buttons.
Because all Samsung refrigerators use a microprocessor to control them, the timing is precisely as given. Since people usually aren't that precise, you may find yourself holding the buttons for 4 or 5 'seconds' before the indicator changes.
Samsung has used a filter indicator like this since the first full-size Samsung refrigerator wa introduced in the United States in Fall 2002. Though the time has varied slightly between models and the 2-button combination has varied even more, the basic process applies to nearly every model that had an ice filter.
Posted on Jan 14, 2009
  • 700 Answers
Press the two buttons on the bottom of your display panel until the icon dissapears and or resets.
Posted on Dec 22, 2008
Symbol of fan and drop of water mean
Likely humidity , either adding or removing with the fan running
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 16, 2017 | Heating & Cooling
Warning symbol
Low fuel. Your car needs a refill and is only running on reserve.
May 23, 2013 | Cars & Trucks
Snowflake symbol on thermostat
Copy following link for Lux product manuals
http://www.luxproducts.com/instructionmanuals.php
It might mean that AA batteries needs to be changed.
Or it might mean 2nd stage heating cycle.
Air filter needs to be changed.
Tech assistance 856-234-8803
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 26, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Symbol still works, but cant turn the "PHONE" on,
whats the full config number from the bakc of the unit - underneath the battery? These units do not come with GSM as standard. We can fix this issue for you, we need to reconfigure a few things and replace a full parts. - If you need assistance with this please contact jack@codeo.co.uk
Aug 02, 2011 | Symbol MC70
Renault clio 2006 model, there's a symbol just below where it gives you the mileage. it looks like a dish with a drop falling into it. What does it mean? can't find that particular symbol in...
A, " drop ",with any symbol is universal for fluid. You may want to check all of your fluids very, very soon. Particularly if the light on the symbol is red.
I hope this helps you.
Feb 02, 2011 | Renault Le Car Cars & Trucks
Symbol on diesel ford excrusion
That is the symbols warning of water in fuel. Generally you will need to have the fuel filter/water separator drained and replaced.
Jan 30, 2010 | 2004 Ford F250
WHAT DOES THE BATTERY WITH WATER UNDERNEATH SYMBOL MEAN
That is the coolant level sensor, its a coolant tank not battery. Means level is low or sensor is bad.
Jul 18, 2009 | 1995 Mercedes-Benz S-Class
The washer will not wash all
Brand of washer, model; front-loader? You can try this:
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 11, 2009 | Washing Machines
It stops in the middle and says 02 f
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 02, 2009 | Kenmore Elite 45986 Front Load Washer
Asterisk symbol Bosch Refrigerator B20CS50SNS
It means it is time to change the water filter. You can hold the button down for a while and it will reset whether you change the filter or not.
Mar 14, 2009 | Bosch Evolution 500 B20CS50SNS
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
2,900 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
