Question about KitchenAid KSRS25IL Side by Side Refrigerator
Kitchen refrig will not dispense ice or water
My kitchen refrig will not dispense ice or water. i had moved it temporarily across the room so i had to turn the water supply off, when i plugged the fridge back in i forgot to turn the water back on. If this caused my problem, what part would i most likely need to replace to fix it? thanks
    Problem Solver:
  • 10 Answers
IF anything went bad it would be the water valve but is shouldnt have failed just because you didnt turn the water on.Just for grins, unplug the wires to teh water valve and plug them back in to make sure you have a good connection.Then unplug the fridge for a minute and make sure the water is on , and plug the fridge back in.Your solenoid may be stuck.THese are just things I would try..I'm mechanically inclined but am not a appliance repairman.
Posted on Feb 16, 2009
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Water dispenser does not dispense water
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door or using a can of computer cleaner ( with nozzle ) has worked ,also , turning on the dispenser light for a while also will thaw . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the line is frozen in the door , GE has a heater , pt.# WR49X10173 , to keep this from happening again . Also , turning on the dispensor light for several hours , has been known to thaw the frozen area
Oct 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
REfrig
whats the model number?????
Jun 02, 2008 | Refrigerators
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Daewoo American Fridge Freezer FRSU20DAI Ice/water dispenser
your refrig should work just fine without water connected to it. just make sure your icemaker is not turned on. it will not harm you refrig to use it without water connected..
Dec 14, 2007 | Refrigerators
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
