Question about Garden
Idels high speed or kills if I try to adjust lower
HUSQVARNA 455 with 18" bar and chain
recently changed air filter
need to choke even when motor is warm to start
Sometimes will run at lower idle speed but will always eventually kill out (approx 30 seconds or less)
Do not assume L or H adjustments are correct.
  • richie felmet Dec 27, 2008
    i have the same problem
  • jcsaws May 11, 2010
    Does it idle slow enough for chain to stop turning at idle?
    if not sounds like air leak somewhere. start checking easy things,
    like fuel line, impulse line to carby, R and R exhaust check piston.
    check no water in fuel . IF these don't help gat back to me ,this is only the start. cheers Jc
  • 36 Answers
Change your intank filter if you have not already. if this does not help turn L idle screw out 1/8 turn.
Posted on Jan 05, 2009
My Rancher doesn't maintain high rpm. What's wrong?
Most 2-cycle chain saws have 3 carburetor adjustments; idle speed, low RPM fuel/air mix and high RPM fuel/air mix. The fuel/air mix needle valves will probably require a "special" driver tool to adjust them. Be careful with the adjustments, you can really mess things up by incorrectly adjusting them, then your saw goes from running poorly to not at all.
Apr 04, 2015 | Husqvarna , No.455 Rancher, 20" Gas -...
My husqvarna chain saw will run only if choke is at least half way out
this is a sure sign of a fuel blockage some place !! id start with fuel filter and air filter and then look closely at fuel lines for signs of collapsing when running (CAREFULLY!!!!!) then move on to cleaning and resetting carb jets
remember choke richens fuel/air mix so if it needs choke to run then it's being restricted in fuel supply
Jun 17, 2014 | Husqvarna Chain Saw 20" Bar
Husqvarna 340 chainsaw will only run for a few seconds on choke, tried cleaning carb, carb adjustments do not help. will not run at all with choke off.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. Make sure that you have fresh fuel mix in the tank (50:1 ratio). Mix the fuel/oil in it's own container and shake the container thoroughly just before adding to the tank each time to prevent oil starvation. When you were cleaning the carburetor, did you check the condition of the lower diaphragm for flexibility with no holes or cracks? Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. Start the engine and allow to warm up, then pull the throttle full on. Adjust the H jet needle CW until the engine starts to speed up. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW for better idle, but allows the engine to 'follow the throttle'. Hope this helps!
Nov 07, 2010 | Husqvarna Chain Saw 20" Bar
Chainsaw quit cutting well, the bar gets half way down in a log and it quits cutting, the engine even starts to choke down
Remove the bar and chain--check the oil port in the side of the engine case where the bar fits up to. Start the engine--oil should ooze out of the port. If not, service the pump, lines and tank filter. If oil does ooze out, clean the chain groove, and the two oil passages that feed oil to the groove. If the outsides of the chain groove have flared out from chain wear, file these edges off (about 45 degrees) til they don't project beyond the bar vertical surface so that they don't catch on the kerf cut. Make sure the chain is being sharpened and adjusted properly. The 'choking down' may be from the engine overheating while trying make the cut. The engine should 4-stroke when running at speed, but immediately 2-stroke when cutting. Make sure the air cleaner and muffler are not plugged. Hope this helps!
May 01, 2010 | Husqvarna Chain Saw 20" Bar
My echo cs440 all of a sudden stopped running at high speed. Starts fine, Idles fine. Just won't run at speed. Air, fuel filters are clean, plug looks good. Choke works fine. Spark arrestor clear. I'll try...
That is where I would go. Maybe carb clean or kit if it is a sudden change.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 01, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chainsaw runs only with the choke on. 3yr old but used by a home owner in a very light frequency
Your Idle and Hi speed jets are out of adjustment. If you look near the carborator you should see two, they usually brass screws. There should be markings by them one HI and the other Low for high speed and idel jet adjustment. You adjust the high speed jet for best running and power while sawing, then you adjust low speed for best idle. This needs to be done occasionally. Or take it in to a service shop. It is best if you learn to do it as from time to time it will be needed. When I was in my late teens I was a logger and these adjustments would need to be done 5 or 6 times a day.
Oct 08, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 142e will not stay running. Going through the sequence of full/half choke it will start and run at high rpm when choked. Even after warmed up, it will die within a few seconds after dropping the...
If it is only running high at full choke - then it is not getting enough fuel.
You've cleaned out the whole thing - so it's not air that's the problem. It's running - so it's not a spark problem - it's a fuel problem.
If you have a fuel filter - change it out or clean it properly. If the fuel line is clear, then you need to adjust the running setting of the carb - there are usually 2 setting knobs -one for idle - one for running / mix.
You need it running richer till you get it going - then trim it back to stop it smoking and get a good rev.
Aug 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Jun 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350 wont stay running?
ok,  The choke is used to change the air/fuel mixture by "choking" off the air that goes to the carburator.  The choke is only used to get the motor running in cold temperatures.  Once the motor is started, the choke must be opened or the motor will flood and stall when you open the throttle.    I hope this solves your problem.  Best wishes, Michael Mittelsdorf
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
107 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
