My remote broke so i bought a universal one and i cant get certain things to work like for example the volume. where can i find a remote that will worl the same as the orignal?
SOURCE: durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
SOURCE: Lost the remote to the Durabrand DVD Model DVD 1002
Durabrand is Walmart's home brand another words they own a company that makes that brand of products so they can sell it all cheaper than any other brand and make more of a profit from it. I could not find the company website so there is no way to order or request a replacement remote. You may have to buy a used one of ebay or buy a new dvd player altogether. I doubt these will work with codes but here you go.
Codes I found that you can try
codes listed: 0003, 0171, 0178, 0180, 0463, and 1034, 189, 220
I hope this helps, even if its not the answer you wanted regarding being out of luck on this one.Thank you for stopping by Fixya!. A Fixya rating would be appreciated if I helped with your question.
SOURCE: Cant find the universal remote code, for my DVD SONY
I suggest getting the original (used) from this site.
http://www.remotes.com/remotes/servlet/rs?a=Previous&o=c&m=DMR&ro=false&qi=101&om=DMR&uuid=12484940834130
SOURCE: Need codes for universal remote for trutech home theater system
hi! i have here two codes for your Trutech DVD, just try them 2345, 2433, hope this helps!!! goodluck!!!
SOURCE: Panasonic SA-HT820V need universal remote that can control radio
I had a similar problem. I disassembled my remote (flat screwdriver and pulling, cleaned the circuit board and rubber buttons thoroughly with rubbing alcohol, then reassembled.
For some reason, the remote didn't work properly until I started pressing the channel buttons immediately followed by the volume buttons. It worked normally, after that. It was most likely due to the not yet dry rubbing alcohol interfering. My remote now works, normally.
