Question about Nokia E71 Smartphone
The screen is dark on my e71; the back light is off
The screen is dark even though I have the display setting at maximum. I am wondering if somehow I need to adjust the backlight; perhaps even turn it on?
    Scholar:
  • 59 Answers
It seems you have a backlight failure. If you can still see the screen on the device (as far as texts and pictures), you would simply need to replace the screen in the device.
Posted on Dec 22, 2008
My lg306g phone's back light goes off after 15 seconds, even though I have it set for 60 seconds.
full factor restore your phone after backing up your phone numbers....this should work......if still problem persists then get your phone flashed.....i.e. get software reloaded
Nov 29, 2014 | Cell Phones
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Nokia e71 blank screen
If the phone is working good without showing any display on the screen , the first step is change another LCD and if the problem still persist contact mobile repairing shop to change the display IC or check it out all the display related components.Good luck
Feb 01, 2012 | Nokia E71 Smartphone
My tch843 screen goes dark after I power it down then try to re start. If i go to a dark room i can see the icons its the same on a.c. or batt. I went to settings and change screen britness to 3 or 4 and...
You have a bad backlight or inverter. The purpose of the inverter is to turn on the backlight. I suspect it's a bad inverter because that is a common problem on most LCD displays and you mentioned it turns on briefly - the backlight lamp is likely good..
Feb 24, 2011 | Mach Speed Trio TCH843 MP3 Player
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
My nokia e71's display frequently goes off and fails to return even after switching it off and replacing the battery. it however still receives calls but am not able to tell who is calling.i wonder whats...
Hi
The problem you are experiencing on your phone has to do with the screen of your phone.
Since the phone comes on and receives calls then all you need to do is to carefully open your phone with a phone screwdriver and check if there is something like an ink substance on the screen.if you see the substance on your screen then your screen could be damaged and you need to replac your screen so that your mobile phone could work perfectly.
BEST OF LUCK
Jun 17, 2010 | Nokia E71 Smartphone
Dark Screen even when i adjust the 'brightness' tab?
check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Jun 03, 2010 | Apple iPod touch
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Nov 14, 2009 | Texas Instruments TI-86 Calculator
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Nokia E71 Smartphone Logo
649 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
