Question about Yamaha DVD-S2500 DVD Player
Yamaha s2500 dvd player
Unit is one yr old . power will not come on. i checked power cord. is there a fuse that could have blown?
  • 3 more comments
  • Jay marble Apr 08, 2007
    did not answer if a fuse is present??
  • xxzzdd Nov 12, 2007
    I was watching a dvd and the picture froze as if there was a problem with the disc. After about 35 seconds my tv screen went blank and I got the no signal screen message - even though the yamaha was still powered up. I tried tomeject the disc and the yamaha would not respond. It would not power off. I then unplugged it in order to hopefully reset it and once I plugged it in again it will not power on at all.
  • reddecks Nov 12, 2007
    Yep mines done exactly the same!!!
    No display lights, just spins up the disc thats stuck in it!!
    Not responding to any buttons or remote!!!!
    Not what you expect from the flagship model!!!
    What can be done??
    Yamaha Service Centre??
  • denisdsjrdns Feb 26, 2009
    Same thing with me!!!! What can one do???
  • avcllc Apr 16, 2009
    Yamaha DVD-S2500 has no power, I have verified that the fuse is good, so problem lies beyond the fuse
Hello, frustrated Yamaha owners.
I have destroyed two of these machines to remove my precious CD's. I did discover this today:
1. There is a fuse but it is soldered onto its circuit board.
2. There is no easy way, like using a paperclip on the old computer cd-rom drives, to release the cd/dvd tray. However, when I destroyed my second player, I noted there is a rather large piece of metallic tape on the bottom of the player to the right side of the front of the drive on the metal bottom cover plate of the machine. It is covering a slot about an inch long. If you carefully remove the tape and use, say a phillips head screwdriver, starting at the right side of the slot as you face the front of the player, you can slide a plastic bar that will free-up the tray slightly allowing one to pull the tray out and save the cd or dvd. I would do this with the player upright but hanging over the edge of a table so that the freed cd doesn't bang around against something in the process.
For what it is worth, I hope this helps.
Yamaha should be ashamed of producing a product at this price point with an issue like this. At the very least there should be a fail-safe way of removing a cd/dvd from the drive regardless of the issue with the electronics or drive mechanism.
Posted on Mar 15, 2009
If the fuse is not blown then buy a new one!
Posted on Apr 08, 2007
Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug.
2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
Nov 22, 2017 | Jwin Audio Players & Recorders
How can a make multiregion my sony bdp s2500
Sony BDP S1200 - Region hack ?. - VideoHelp Forum
forum.videohelp.com > Forum > Hardware > DVD & Blu-ray Players
Dec 14, 2014 - 13 posts - ‎7 authors
Hi peeps, My old Phillips Blu Ray gave up the ghost this week, ... especially bluray players. usually only the dvd side can be made region free. Sony BDP-S2500
Nov 30, 2015
Jan 26, 2010
Samsung BD-P2500 - All Regions Hack Required
Dec 1, 2008
More results from forum.videohelp.com
Multiregion sony bdp s2500 - Fixya
www.fixya.com/support/t25991992-multiregion_sony_bdp_s2500
3 hours ago - multiregion sony bdp s2500 - Sony DVD & Blu-Ray Players question. ... How can a make multiregion my sony bdp s2500 Multiregion. Dec 03 ...
Sony BDP-S580 multi region DVD hack with URC-3440 ' AVForu
Dec 03, 2015 | Sony Televison & Video
Tv started having problem. Decided to play dvd to see if it was tv or dish? When try to play dvd player would not turn on. I see cable is connected to it and then to tv. So can we trouble shoot dvd...
Hi welcome to fixya
do you mean the dvd player won't turn on ?.if no power at all you will need to unscrew to open the cover.now if you want a DIY... you must have the necessary tools like phillip screw driver and digital tester. then you must check first the fuse at the power supply unit if blown. the power supply, this is where the power cord connected if the fuse is totally burned before you replaced the fuse you will need to check shorted diode and transistor which cause of the fuse to blown. and then just replaced the fuse with then same rating capacity that is label in the board. thanks hope this can be helped, feel free to ask further solution just let me know if this is what you asking for, i'm glad to help you to diagnosed and fix the problem.
Dec 10, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
My dvd wont turn on there is no power going to it
Hi:
Take the top off the unit and check the AC fuse for an open condition, The fuse is near where the power cord enters the unit. If the fuse is blown then there is a problem in the primary side of the power supply.
Jan 23, 2011 | LG RH266 Recorder
I plug in my DVD player and I get nothing, not even the power light comes on....
You have a power supply problem, if the cord is detachable from the player make sure it is snug tight, next pull the cover off and follow the cord to the power supply board to see if the fuse is blown, the other thing I come across is a bad capacitor near power transistor but this will require some technical know how. One final thought, check your unit on another wall receptacle.
Jan 12, 2011 | Toshiba SD-3980 DVD Player
Power supplierd but does not start recorder no
Hello:
If the unit is competely dead, then you may of blown a fuse or the power supply has failed in the unit. If you take off the top of the unit while unpluged check the fuses near where the power cord attaches to the inside of the unit this is the power supply area, If you have indicators lit or the display is coming on then the unit may have a bad power supply or the System control board has failed. It which case its cheaper to just purchase a new unit.
Jul 14, 2010 | Panasonic DMR-E85H DVD Recorder
No power
The outlet that the unit plugs
into... Is it 'hot'? Plug in a known working Table
Lamp. If you have power, the problem is the unit.
Where the cord goes into the unit, locate the Power
Supply. Carefully check for any cracked, blackened,
or broken components. My educated guess is that
a small fuse blew, as did the Metal Oxide Varristor,
which is either a large blue or red disc shaped component
near the power transformer. If the fuse is blown black
inside the glass, this indicates a short, and would require
an Ohm Meter to locate it. If the fuse is blown so that
the element inside just melted open inside the glass,
this indicates an overloaded condition, and would require
that the fuse be replaced with a rating 1/4 amp greater
than the original fuse. Why? because most fuses are
under rated to insure that they will need service to keep
people like me from starving! Trust me on this one.
good luck!
Jun 26, 2010 | Memorex MVD2042 DVD Player
No power no responce from unit fuse and cord are good
Check to make sure that your power supply printed circuit board is getting power from the wall socket and if so, check for any blown components, most likely a capacitor on the power supply circuit board. I hope this helps. Good luck.
Nov 26, 2009 | Emerson EWR20V4 DVD Recorder/VCR
No power
1. Check that the AC outlet is working.
2. Check that the AC power cord is ok with no damage.
3. Unplug the unit, remove the cover and check for a blown fuse.
If blown, replace with a value that is the EXACT value as the original.
4. If the fuse blows again or the unit is still dead, you most likely have a problem in the power supply section.
In that case, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Mar 19, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My kvt 617dvd is dead
hey did you check the fuse in the relay box on the yellow wire?
if you cant get it fixed then sell it to me real cheap my board went out on mine and kenwood dont sell boards and the repair center cant fix mine.
Oct 07, 2007 | Kenwood KVT-617DVD Car DVD Player
Yamaha DVD-S2500 DVD Player Logo
468 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
