Hi - The other morning (more like 4 weeks ago) I woke to the Bosch dishwasher (SHX46A05UC) leaking. I shut off the hot water line and the leaking stopped. That morning was the first morning above freezing in 2 weeks. The floor below is poorly insulated. I'm guessing a line or part cracked because of freezing/thawing. Online forums suggest it might be a broken water inlet valve. What is the correct sequence to troubleshoot the problem? And how can I repair it myself? Thanks in advance for your advice and help.
Comments:
Apr 12, 2007
- I ended up looking at the hose and found no problem - fortunately it was well insulated from tap to machine. On turning the water on the leak came fromthe front left of the machine. Turns out the plastic body of the water valve had split and leaked the water. Thanks for the suggestion.
could be the valve but more likely is the fill hose itself. pull it out, turn on the water and check the hose carefully especially at the ends wher it joins onto the tap and the machine
My SHX46A02 won't power on. It is a Bosch dishwasher. My question is do these dishwashers have a...
(More)
My SHX46A02 won't power on. It is a Bosch dishwasher. My question is do these dishwashers have a fuse in them?
I have a Bosch dishwasher SHX46A06UC/14 that won't drain or cycle. It fills with water. tried...
(More)
I have a Bosch dishwasher SHX46A06UC/14 that won't drain or cycle. It fills with water. tried changing the main circuit board control panel. That didn't fix it. What next?
Our dishwasher ionly 14 monhs old and doe not clean proprly.Heavy film left and we hve tried...
(More)
Our dishwasher ionly 14 monhs old and doe not clean proprly.Heavy film left and we hve tried different type detergent and rines. Also the inside smells terrribly at times. Smells rotten. After the cycle is finished there is still wter in the drain area.
