Question about Canon PIXMA MX310 All-In-One Printer
Ink is low unable to scan/fax
I can't seem to bypass the 'check ink' message and the alarm light is on, however, I don't want to print I just want to scan or fax
I had the same problem. I had just installed new black ink cartridge and had the same problem "CHECK INK" and alarm light is on. My color ink had just runned out. I was just about to go buy the color ink to see if it would fix the problem but decided to try it one more time. This is what to do..Click on the print command and a cannon message will pop up saying that you have no ink (it being the black or the color) then you will get the CHECK INK message all you have to do is PRESS the "Stop/ Reset" button for atleast 5 seconds and it will let you print..
Posted on Jan 11, 2009
    Genius:
  • 2,120 Answers
Canon wants to sell ink cartridges. That's how they make their money. No way around this problem without installing new ink.
Posted on Dec 22, 2008
Trying to scan but says low ink and wont scan
You can go to printer preferences and change the setting to print Fast and Grayscale. That should allow you to scan and print if needed until the ink cartridges are replaced.
Mar 06, 2014 | Canon MP560 All-In-One InkJet Printer
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I want to scan with canon mx330 without ink in the printer
I have a canon mx330 fax print and scan all in one printer
To scan without ink just hold the back button in after the ink message comes up it should eventually take you to the main menu then you can hit the scan button.
Mar 10, 2012 | Canon PIXMA MX330 Multifunction InkJet...
I am unable to retrieve fax from memory, on the Fax Setup menu no reference to faxes in memory. I have a Lexmark 6650. When the fax wa sent it said "printing" but nothing came out
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Aug 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I am having trouble with the printer. The DR is working fine. It sounds like it is printing, however it does not. print. There seems not to be a problem with ink The printer is not printing. I...
Definitely you have a problem with the printer.
That will not prevent you from sending faxes out, but did you try to make a copy?
If the machine sat idle for some time, the ink in the jets would have dried, but this will not generate any error messages.
There are cleaning kits available, and they usually work.
May 31, 2011 | HP 1040 Plain Paper Inkjet Fax
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
May 29, 2009 | Canon PIXMA MX300 All-in-One Printer
Low ink message with incoming fax, no fax but printing works fine
Unplug the machine for 3 minutes and plug it back in. sometimes this will reset everything. good luck
Feb 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon MX310 - Fax - Waiting for report
My INK Level was Low and I had the setting "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report would not print due to the ink level being low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed immediately, and the message will disappear.
Jan 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
571 people viewed this question
old marine
old marine
