Question about Reddy Heating & Cooling
No spark to igniter
When I plug the unit in, the fan starts and fuel sprays out of nozzle. I am not getting any spark to the igniter. What type of voltage should I be sending to the igniter module?
  • 232 Answers
The ignitor does not spark- it glows.
Posted on Dec 23, 2008
Heater would not start this morning It tried for a second and then just would not ignite. it was running fine yesterday
Take the top cover off of the unit. Plug it in and look at the ignitor for a bright glow or spark, depending on your ignition source. This should happen before the fan starts. Once the fan starts you should be able to see fuel spraying out of the spray nozzle. If there is no fuel, check the fuel screen, air output from the pump, air filters on the pump, and the correct air pressure from the pump. The nozzle can also be dirty. Check for air leaks on the pump by spraying soapy water on the pump while the blower fan is running.
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My Reddy Heater 50,000 btu kerosene heater does not ignite when turned on and shuts off after about 4 seconds. Could it be that it is too cold? It has been in the garage during freezing temperatures, but...
Take the top of the heater off. It should be about 6-8 screws holding it on. Be careful around the fan and plug the heater in. Check for the igniter sparking if it is the spark plug type or glowing if it is the HSI(hot surface igniter) type. If it isn't, check the gap on the spark plug and you will have to check the transformer for it also. If it is a HSI, make sure it is broken. This type is very brittle and easily broken. Next use a flashlight to look for fuel spraying from the nozzle. If it isn't, the fuel nozzle may be clogged. You can use a very small piece of wire to push through the nozzle to clear it. Also check the fuel filter. You can check for water in the fuel tank too. If it's really cold it could be frozen blocking the fuel flow. If you still don't have fuel flow, check the air filters. There are 2 on the back of the fan motor. You will have to remove the black cover to see one of them. Let me know what you find if you don't get it fixed.
Jan 09, 2011 | Heating & Cooling
Heater will not start
Does the blower motor start when you plug it in/turn it on? It may take around 5 seconds if your heater has a HSI(hot surface igniter). If it does you need to check the igniter and the fuel flow. Either way, remove the top of the heater. You will be able to see the fan, igniter, and fuel nozzle. Turn the fan by hand to see if it turns freely. If it does, watch out for the fan and turn the heater on. Look for the igniter to start sparking (spark plug type) or glowing (HSI type). Next, use a flashlight to look for fuel spraying from the nozzle. If fuel isn't spraying, try cleaning the fuel nozzle and check the fuel filter. Watch out for the HSI, if you have one, they are very brittle and easily broken. If you still don't have fuel flow after cleaning the nozzle and the fuel filter, you may have an air pressure problem. Let me know and I will tell you how to check it. Don't forget to rate the answer if it works.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I plug my reddy heater in and it comes on then shuts back off. What is the problem?
Try cleaning the flame sensor. Remove the top of the heater. The flame sensor is a black rubber boot close to the fuel nozzle. Pull is out of it's holder and use a soft cloth or cotton swab to reach into the openning and clean the eye. While you have the top off, watch out for the fan and turn the heater on and use a flashlight to look for fuel spraying from the fuel nozzle into the burn and make sure the igniter is working. I don't know which type you have but it may be the spark plug type or a hot surface igniter which should just glow red hot. Let me know what you find.
Jan 02, 2011 | Heating & Cooling
Fan kicks on and heater will not ignite
Remove the top of the heater and turn it on. Look for the igniter to start sparking if it uses the spark plug type igniter or if it uses a HSI type, look for it to start glowing. Next, use a flashlight to look for fuel spraying out of the nozzle. If it isn't check the nozzle for a clog. Check the fuel filter. Remove the filter cover on the back of the motor and check the air filter. If this doesn't get the fuel going you will need to get a pressure guage to screw into the left hole in the filter cover and check the air pressure going to the fuel nozzle. It should ~3.5#. You can adjust it by turning the adjusting screw in the other hole in the filter cover. That plug should have a hole in it.
Dec 29, 2010 | Reddy REDR40T Heater
When turning on My dyna pro 6500 heater. The fan will kick on for about 10sec then it will shut down and the red light will blink. How do I fix it
I have several of these in my shop. When they act up it is usually carbon deposits blocking the fire eye. This is a sensor that detects flame, if no flame is present it shuts down the whole heater. Remove the upper cover of the heater and attempt to start it, watch for 1- spark from the ignition sorce 2-fuel being sprayed from the atomizing nozzle 3-ignition of fuel. No spark bad spark plug or ignitor, no smell of fuel or small cloud of fuel, bad fuel filter, no fuel, bad fuel line, bad or plugged nozzle. There are several things that cause this but these are the three most common problems I encounter.
Dec 10, 2010 | Desa International R40 Utility Heater
Hear ignitor clicking but unit doesn't light
the clicking indicates a spark plug ignition. see if the spark is created across the spark plug gap. if it is then check the alignment of the plug in the nozzle spray pattern. if there isn't any fuel flow then all the clicking ain't gonna make any difference in the world!
Oct 13, 2009 | Reddy R115DT Oil Filled Utility Heater
Reddy Heater runs but will not ignite with bonnet attached.
First, let me say that the general principal of fuel delivery ***to the spark plug*** depends on several things.
  1. Proper air pressure at the nozzle (provided by the rotor/motor)
  2. Proper “fuel pattern” at the nozzle (provided by the rotor/motor/nozzle)
  3. Proper amount of ***air & fuel*** at the nozzle (provided by the rotor/motor/nozzle)
  4. Proper ***air flow (cfm) through the combustion chamber (provided by the fan blade/motor)
  5. Proper rpm’s of the motor, which affects all of the above.
On your heater the first step is to set the air pressure to specs. Instructions are on the www.reddyparts.com website. This pressure setting directly affects fuel delivery & fuel atomization
This nozzle rule will only apply if everything is correct as far as fuel delivery applies. The pump pressure must be correct- not almost correct. Set the pressure with a low-pressure gauge that registers12-15 psi max. A gauge with a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the above rule will not apply. Instructions for setting the pressure can be viewed at http://reddyparts.com/pressure.htm.
  • Next, if the fan is OK (correct & intact) look at the NOZZLE. DESA recommends annual replacement of the nozzle, which is a wear item. Naturally, annual usage varies, so, wear will depend on annual usage. A worn nozzle produces a cone shaped SPRAY rather than a cone shaped FOG. A spray drowns the spark, where a fog gets ignited, provided it contacts the spark. ALSO, the pattern from a worn nozzle can completely miss the spark (combustion??? Hardly!). When the top is lifted the change in airflow allows a false correction in the combustion chamber, allowing combustion, but when the top is replaced the flame is extinguished. A restricted nozzle or a restricted fuel filter will also distort the fuel pattern and create the same symptom. Also, like the fan blade, make sure that the correct nozzle is installed. Nozzles get swapped, too.
Dec 12, 2008 | Reddy Heating & Cooling
Won't fire up
Silvercliff- since you use the word “plug” I am assuming that you have a spark plug type heater, not the new technology HSI type (hot surface ignitor) that uses a glowbar and an onboard computer.
Reddy heaters are simple to troubleshoot, but you must understand how the system operates.
Since you state that the heater produces a fog at startup indicates that you are getting “some” fuel.
Obviously, the fuel is not igniting.
Now, you must determine if there is any spark. Is a good spark arcing across the electrodes on the plug? If not, is spark being produced by the Ignition Control unit (aka spark box, transformer) ? If not, is the Safety control (reset) sending electricity to the Ignition Control unit?
If there is a good strong spark at the plug, then you are having a fuel delivery problem, even though there is “some fuel”. Understand that the amount of fuel being delivered to the nozzle is DIRECTLY related to the air pump pressure. If the air pump pressure is not correct, then the fuel delivery is not correct. Setting the pump pressure is not difficult. Pump pressure is CRITICAL. Instructions for setting the air pump pressure can be found at www.reddyparts.com .
If the air pump pressure is correct, then check the following:
  1. Cracked air line preventing correct pressure at the nozzle.
  2. Cracked nozzle adapter preventing the fuel from being SUCKED from the tank.
  3. Clogged fuel filter.
  4. Restricted or worn nozzle. The fact that your heater is a spark plug type heater indicates that it has some age on it. DESA recommends annual replacement of the nozzle. Are you using the original nozzle? Worn nozzles produce a SPRAY. New nozzles produce a FOG. The nozzle produces a cone shaped fog. If the cone is missing (not hitting) the spark, for some reason, then there will be no ignition.
  5. Finally, and don’t laugh, is your fuel 100% kerosene or diesel? Water sinks to the bottom of the tank. The heater draws fuel from the bottom. If there is an inch of water on the bottom…….., well, water will not ignite.
I hope this helps.
Aug 28, 2008 | Reddy Heater-30-55,000 BTU Variable
Kerosene forced-air heater won't start
Rick---A couple of things to check. With the unit off and unplugged, remove the spark plug-(Note-there may be a little setscrew which you have to remove first)----Put the plug wire back on the plug and ground it against the side of the heator and start it just briefly to see if the plug fires----If it does, then again with the unit shut off, remove the nozzle which has a set screw holding it in. The nozzle has 2 rubber lines running to it and leave them on and then start the unit (Note, be aware that in this test and the plug test that when its plugged in, the fan runs, so keep the plug wire and the rubber lines away from the fan) With the nozzle removed, watch very closely to see if a mist comes out of the nozzle after you plug it in. If no mist comes out, then you probably have either an air or fuel problem.---With the spark plug test, if there is no spark at the plug, the easiest way is to install a new plug and if there is still no spark, then the ignitor is probably bad----------On the nozzle test, try taking off the 2 lines on the nozzle, one line goes to the fuel tank and the other line is the air line (take note which line goes where) first blow thru each connection on the nozzle to see if its plugged and if its not then blow thru the hose going to the tank and you should hear a bubbling noise in the tank--if not then, its plugged or the hose is split----------The other line is the air line and if you can't get anything on it, the filter may be very dirty----behind the filter, there should be a port for checking the air pressure when the unit is running----The unit I have runs on 3 psi pressure, BUT yours may run on a different setting--That psi setting may be stamped on the unit behind the filter---Hope this helps
Nov 10, 2007 | Heating & Cooling
Heating & Cooling Logo
139 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Superior Maintenance
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
