Question about Ricoh Aficio AP3800C Laser Printer
SC680 error message on a Gestetner DSc38
I have received an error message of SC680. It first said to reset the black toner, I took it out and put it back. Turned the printer off to reset it, but nothing has helped
  • Marco_Polo May 11, 2010
    from the manual: SC 680 BCU/ MUSIC communicatio n error After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times. ? Toner cartridge memory chip loose connection ? Memory chip problem ? Memory chip cable wiring problem 1. Turn the main switch off and on. 2. Check if the toner cartridge is installed correctly. 3. Replace the toner cartridge. 4. Check if the harnesses are not damaged. 5. Replace the BCU. HTH
  • 32 Answers
The machine has a problem reading the memory chip on the toner.
Check if the chip is not lose or damaged or durty
Check the harnass or the chip reader and pins and clean.
Replace toner
after replacing the toner and the problem is still there you can do a engine clear.
contact me drbrain@webmail.co.za for doing engine clear.
Posted on May 08, 2010
Toner reset
SC680 is a communication error, usually relating to the chip on the toner cartridge. Check that it is clean and that the electical connection is properly made when the cartridge is in place. It can result from a wiring error, but that is much less likely, and a failure of the BCU board - even less likely. Hope that helps.
Jan 17, 2014 | Ricoh Office Equipment & Supplies
Gestetner dsm730 error code sc590
SC 590 - Toner collection motor error.Possible causes:
- toner collection motor defective
- too much load on the drive mechanism
- poor toner collection motor connector connection
- toner collection motor sensor defective.
Reset procedure:
1. Turn OFF/ON the power switch.
If the trouble don t reseting press the Clear (yellow) key press 107 press and hold last more 4 seconds the Stop/clear(red) key,enter inSP mode,then turn the main power switch OFF/ON.
Feb 04, 2013 | Gestetner DSm730 Black and White Copier
Am getting a functional errror on our gestetner dsc424 to replace developer units magenta and yellow. replaced both toners, but error message will not clear, even after turning off and then on again. can...
Hello!
Did you mean what you are saying?
If the machine are telling you to change the DEVELOPER UNIT why did you change the toner and hoped to reset the massage?????????????
If the machine are telling you to change the developer unit you need to change the developer unit!!!!!
Do that and your problem is solved
Sep 09, 2011 | Gestetner DSc424 Color Copier
RICOH 2238 C ERROR CODE SC680
SC 680 BCU/ MUSIC communication error After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times. • Toner cartridge memory chip loose connection • Memory chip problem • Memory chip cable wiring problem 1. Turn the main switch off and on. 2. Check if the toner cartridge is installed correctly. 3. Replace the toner cartridge. 4. Check if the harnesses are not damaged. 5. Replace the BCU.
Mar 12, 2010 | Ricoh Aficio Type 2238 (411603) Print...
Error message keeps showing to "reset black toner".
Try to reset the toner by taking it out and putting it in again.
Jul 16, 2009 | Ricoh Aficio AP3800C Laser Printer
Hi again! i have a multifuctional machine gestetner dsc428. i print 500A3 full black with b/w print option from the driver checked. After i finished the prints my machine shows a message on screen tha...
Are you using third party toner, or OEM? Toner cart has small chip on it that the machine reads and is being told not OEM toner
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 09, 2009 | Gestetner Office Equipment & Supplies
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Color registration
Whenever you change the fuser unit you have to do the fuser registration.You have to use the manual feed tray with A3 or 11x17 paper for this registration.The details should be inside the new fuser box carton.
May 16, 2008 | DSC GESTETNER - DSc38u Color Printer
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
Ricoh Aficio AP3800C Laser Printer Logo
758 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
