Question about Nikon EM 35mm SLR Camera
Exposure button stuck and will not work
Nike manual FTN
  • Anonymous May 24, 2009
    same
  • Timm Chapman
    Timm Chapman May 11, 2010
    This is likely a sign that your battery is dead. Have you tried replacing it with a fresh one?
    I am assuming it is a Nikkormat FTN, since you didn't specify whether it is a Nikn F with an FTn meter or a Nikkormat or Nikomat FTN.
    Problem Solver:
  • 17 Answers
Depress & hold the button near the film speed dial and set the dial to 60 or 90 which ever speed it shows in a different color than the others as seen. This make unlock the shutter
Posted on Mar 07, 2009
I have a Nike WC0021 watch and it beeps every hour. How can I turn it off?
Press and hold the top right button for 3 seconds then release - this should turn off the 'chime' function.
May 31, 2016 | Nike WC0021 001 Mettle Hammer watch
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
The start and stop buttons are stuck. so I can't even change the time or use the timer and any other funcion! They stayed down and I am not able to take off.Nike Triax mia
Did you just have the battery changed? Sometimes once a watch is open and things are moved around, the connection wires that are pushed by the buttons will need to be adjusted.I would take to a watchmaker/jeweler to have looked at.
Aug 18, 2010 | Nike Black Triax Mia Watch WR0104 001
Can get the light to work on my Nike watch
You can get a manual from their web site. Go to http://www.nike.com/timing/ and click on "collection"
Find your watch and click on "product resources". You will be able to download a copy from there.
May 31, 2010 | Nike WR0099 017 Mettle Anvil Comold Super...
My Canon xsi's exposure lock button is stuck
Sounds Like the Camera is the one of the Full Auto modes were the exposure is selected by the Camera. To select you own exposure levels you must set the camera on the top dial to P, TV, AV or M.
Oct 12, 2009 | Canon EOS Rebel XSi Digital Camera
How to use the function buttons on Nike WC0061 watch
very cool watch, but very different programming...
http://www.nike.com/timing/extranet/product/imarastrive/imara_strive_manual_eng.pdf
will take you to a 2-page manual, better than the original!
i
Jun 05, 2009 | Nike Wc0061 040 Imara Strive Watch
How do u do this
Below is the link for manual to the C3 watch in question. From what I can tell, you need to do the following to set the time:
1. Push MODE button until you reach TIME MODE.
2. Hold the START/STOP button for 2 seconds. I believe the HOUR will start to blink at this point.
3. From here on, one of the buttons will scroll through the HOUR, MINUTES, 24HOUR FORMAT, and the other will be used to adjust them, I am just not sure which it is, but with the PDF MANUAL link below and trial and error, you will get it done in no time flat!
This link will take you to the C3 manual in PDF FORMAT:
http://www.nike.com/timing/extranet/product/triax_c3/c3_manual_eng.pdf
This link is for nike support on the C3, by phone, email, even live chat!
Enjoy your Nike watch!
Dec 31, 2008 | Nike Triax C-3 Wrist Watch
Sony TRV460 exposure problem
Its not common problem in Sony cameras. I think, aparture got stuck but I wont advice you to repair it by yourself. Contact nearest Sony Service Center for good repair.
Jul 16, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Jan 27, 2008 | Nike Triax CV10 Wrist Watch
Nikon EM 35mm SLR Camera Logo
177 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
