Question about Jenn-Air 30 in. CVE3401 Electric Cooktop
Jenn-Aire Cooktop Glass
I saw your post from this past summer and noted that you had found replacement glass for your CVE3400B cooktop. My daughter is at my mother's baking for Christmas and dropped a 20+lb turkey on the left glass of her CVE3400W cooktop. I have been unsuccessful in locating replacement glass up to this point. Can you tell me where you found yours? It'll save me from having to replace her entire cooktop.....thanks so much.
  • Anonymous May 02, 2009
    Could someone please tell me where can I buy replacement glass for my Jenn Air CVE3401 black cooktop. It has cracked.
You can order the replacement glass for about $225 from companies like Repairclinic.com or appliancepartspros.com
Part Number: AP4095442 made by WHIRLPOOL, black
Part Number: AP4096135 made by WHIRLPOOL, white
Posted on Sep 18, 2009
Eddie Rentas
  • 59 Answers
SOURCE: replace glass top
Hello Bob
I have attached the link for you to request the manual for that stove....just go there and fill out the form and they will email you the manual in a few hours....I did the same thing and I got it the same day.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
aborcass
  • 2651 Answers
SOURCE: Cooktop wiring
usually black(120v) white (n) and red(120v) bare wire to ground, but if htat what yo got and your sure of incoming voltage, blabk to black , red to red, and white to white is normal..co loang as you 2 power legs are hooked to either power line, the bare goes to the nuetral/ground. thikn i mighta confused myself here, but theres no other way to wire it
Posted on Nov 10, 2008
  • 13433 Answers
SOURCE: Jenn-Aire ccg2523 Natural Gas sealed cooktop.
parts for your cooktop are available at
http://www.partselect.com/MultiModels.aspx?ModelNum=ccg2523&searchTerm=&RefineSearch=0
have a look at the part diagrams, they may help you on taking it apart.
Posted on Jul 02, 2009
I have a Cooktop Jenn-Air Model JED8430. The cooktop glass is broken. Would it be possible to change only the glass? If so, where could I get an other one ?
Yes, you can change just the glass. It is called the maintop assembly and usually starts at $275 and goes up. You will need to get the remaining 3 digits for your particular model in order to get the right glass. A good place to start looking would be: http://www.searspartsdirect.com/partsdirect/part-model/JED8430?pathTaken=modelSearch&prst=0&shdMod=JED8430
Apr 15, 2011 | Jenn-Air JED8430 Electric Cooktop
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    How to repair cracked corner of black ceramic cooktop
    Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
    Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
    Jenn air cook top
    Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
    To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
    I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
    PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
    Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
    Jenn-air JED8430 cooktop
    Fairly difficult but doable for the mechanically inclined. They are all a little different - look underneath to uninstall the entire unit (turn off power first!). It is probably held in by a few screws. The glass is likely held by screws underneath as well. Hope this helps!
    Dec 28, 2008 | Jenn-Air JED8430 Electric Cooktop
    Replace glass top
    Hello Bob
    Eddie Rentas
    Tupper Lake NY
    Jul 18, 2008 | Cooktops
    Broken glass cook top
    The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
    Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Pitted glass cooktop in Jenn Air Model JGC9430ADS
    Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
    Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
    Cooktops Logo
    592 people viewed this question
    Top Jenn-Air Cooktops Experts
    Marvin
    Marvin
    Paul Carew
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
